ive herd about the mini me swap a few times but still dont get what the hell it is n all about it so if someone could tell me somethin id appriciate it alot
you swap your existing head for a diff one its really simple undo your intake manifold timing belt distributor exhaust manifold take off old head scrape old head gasket off the block install new head gasket install new head put intake manifold exhaust manifold distributor and timing belt onto new head and retime you car see? easy as 1-2-3!
And run wires for VTEC and swap the ECU out for a P28 or something else that will run the motor correctly.
Here, there's a wonderful website called "google" where you can actually search for stuff on the internet. I searched "mini me faq" and came up with a bunch of different write-ups on how to do it:
