HondaElite
senior member
i have a d16z6 head on a b7 block..basic mini me..i was wondering why it would rev like this?...could it be timing? thanks guys
There can still be leaks. Also, leaks can come from gaskets or components not being tighted all the way(like IACV, throttle body, intake manifold, etc.)
the vacuum lines can be hooked up and still leak.. while the car is running spray some carb cleaner around the base of the intake manifold, throttle body, sensors and vacuum lines... if you have a leak it'll start to die out when you spray where the leak is
