How much would you pay
hazzardboy95
Hon-daaaa
My friend is picking up a 1991 crx with a jdm b16 swap, lsd trans, hasport mounts, hasport shift linkage, full upgrade integra brakes front and rear, steel braided brakes lines, skunk2 manifold, aem rail, aem regulator, cold air, clean interior, slight body rust, jdm fenders, hood, front bumper, and other little goodies.
One million dollars maybe?
test drive it. have a friend hop in, put e-brake on and do a burn out. if both wheels spin, 3k-4k depending on the overall condition of the body, interior and any leaks. if only one wheel spun, i'd thank the guy for his time, then apologize for catching him in a lie and wish him luck screwing the next guy over.
Lsd is stamped into the trans up near where the tag for the block identification, its not an after market lsd its straight from japan lsd.
you do realize you can test for lsd by jacking the front and spinning one wheel and if the other spins the opposite direction its lsd.
Funny you should say that cause after checking for bad wheel barrings on a few previous cars in my days they all did that and they wernt lsd cars.
what cars were they? if it is an open dif, one will spin and the other shouldn't do anything.
no more than 3500-
and get_nick,,your theory isnt exactly true,,my d16 si spun the tires 2 diff ways,
you should be able to tell when going around the corner and giving it some throttle,,it will feel way diff, than a normal trranny
$0.27 or best offer who knows with out looking at it thats like saying how many beans fit in a corn bag. you dont know till you try it
Whether you pay $3000 or $5000 all that matters is that you are happy. I have well over that in my car. If the work was done right and it looks like a decent car then make an offer. It would cost more to build a car than to buy it. Post up some pics so we can get a better idea.
If i can i will, oh and as far as lsd, both tires should spin in the same direction if you jack it up. Not exactly sure if its the same on a fwd but in rear wheel drive there is a spring pushes up against two small clutch packs in the diff and when the ass end is up they spin in the same direction cause the clutch packs are stuck together. It takes driving around corners to make the axels spin at different speeds to make the clutch packs release. I know its not exactly the same but its a concept.
