d16z6,d16a6,si parts
INJEN78
HS LEGEND
2 d16z6 heads-completely assembled
vlaves,springs,retainers,rocker assembly,vtec sol. valve cover,waterneck-everything-you just need the manifold
no bent valves,worked great before pulled
also have stuff from a d16a6-shift linkage,axles,tranny,exedy stage 1 clutch,mounts,ecu
make an offer on anything
id like to have a 88-91 si tranny
i think i have 3-the drivers side,the passengers side,and the rear tranny with the bracket,,if those are what you mean,then make an offer.
sold everything but the d16z6 head and the pm6 ecu,,,make an offer
