I got a d16z16 with a p28 in my 24 hours of lemons racecar and heard of performance going to the p72
But want to make sure it has a rev limiter still does it and what rpm
The P28 is the stock ECU for that motor, and it's very easy to chip and tune. Why would you want to run an ECU that's for a completely different engine?
because people assume that because an ecu is from a "higher performing" motor it will make their shit faster or better. They don't understand to use the right ecu or an ecu chipped to their setup. Also seems they don't know when it is time to consider chip and tune. It is quite sad really.
