I recently wrecked my DA.( r.i.p.). I have a 90 Si hatch, I plan to swap motor (OBD1 B16a) and other components, if I can. My questions are:
1. Can I use any of the suspension components from my DA on my EF? (knuckles, control arms, axles, shocks...etc)
2.Let me know if I'm missing Anything. Obd conversion requires
a.ECU jumper harness
b.Dist. rewiring/harness
c.Injector clips switch? may or may not need to be done?
d. 02 sensor
3. Does this mean I can just plug in harness without changing clips/plugs for every sensor?
I have performed engine swaps. I had never converted OBD. I know this information has probably been posted a thousand times. If you dont want to answer any questions PLEASE post links to info.....Thanks everyone
d. 02 sensor
