Need random Nissan brake part
Capt. Orygun
Win the Day
So I have my new R33 front calipers (exactly the same as 30MM 300ZX calipers)
the problem is those little solid metal lines that screw into the caliper and connect to the brake line, yeah I didn't get those
I did some checking online and I don't see anything readily available, but my only other option is doing custom lines with some kind of 90 degree angle hose fitting
IMO OEM is the better way to go, so I need the lines, anyoe know where to score some?
i don't know about new parts, but i know you can get some used parts pretty easily. call a company that imports clips. there is a shop here in tacoma that has a ton of clips. it's called "fairlady z".
i'll sell you one for $800. comes with rear brakes too...
p.s. i think i'm going to be selling/parting out my car next month.
if you part it out I'll take your whole rear assembly (with the ebrake assembly mounted) and the front calipers with hardware, anything else that will convert to my S14 I would be interested in too so let me know
alright, i'll let you know. i might not take it apart because i could sell the whole 5 lug conversion as a unit.
i do have an r32 vlsd...silk road coils...um...can't think of other stuff you might want.
