Yeah it shouldn't really be that hard. Just remove all parts of the factory intake system (including the black plastic resonator pieces that go down into the fenderwell) and install the new intake pipe in it's place. Use your hose clamps to attach it to the throttle body and to attach the pieces together. You may have to mess with the vacuum hoses a bit to get everything to work correctly. Also, you may have to widen the hole in the bottom of the bay where the intake pipe exits down into the fender well a little bit. I'd probably use a dremel or Sawzall for that, if you have access to them.
Good luck...
