1 wrecked, 1 modified
-sorry for all the cell-phone pics
love those rims what are they
I'll be the first to say, that will buff right out.
aren't those the 50 lb wheels you were looking at a long time ago?
Possibly, I've had these for like a year and a half and this weekend is the 1st time I've put them on a car. They're about 18lbs a piece ;)
I've got some hankook r-comps on a decent set of konigs (11lbs) for autox.
primered
should be resprayed within the next few weeks (original color...black)
Just swap the v6 into the rex. It would be like a faster version of the golf r32. With somethin like 320 horses at the crank already. That would be sick. Are the cl-s awd?
how about just leave it alone because it is beautiful as is? :wub:
x2 on the rex (drool!), also wtf did the lady hit with that car? so weird to see the headlights unaffected.
rear-ended a new Accord
the CRX has a browntop ZC in it....vac adv distributor and all :) (de-vac'd, removed charcoal and EGR canisters)
also has a shitload of suspension upgrades, front and rear 1g teg brakes (rear disc)
You know putting the stock intake back on there, you'll gain about 5hp and 5mpg.
its a track car
the filters only on there because I had just de-vac'd the car when I took it
the intake I had was an OEM with another tube routed over to the lower grill and the top half of another OEM air box mounted to the back of the grill as a pickup
I have a (half built) turbo D16A1 that will hopefully be done/installed before the fall
You goin mini me with the d16a1? Check out the car on the front page of homemadeturbo.com. That guy runs mid 11's with a vitara setup in a a6 block with a y7 head I think. Stock block other than the vitara's, and head.
