h22 problem
dalton1421
ok so heres the deal i have a 91 accord and i swapped it out for an h22 when i first did it i just did the engine and the vtech worked fine now though i put the h22 tranny on now the v tech doesnt want to come on dont get me wrong the car sat for a lil while due to my lisence being suspened i know where the solenoid is but i dont know how to tell its bad or not also i check the check engine light codes and it is 7 and 6 any ideas of what those codes mean also the idle sometimes bounces and today it stayed at 2500 i dont know where the ivac is so can yall help me out i apprechiate it im going nuts lol
Reference Materials - HondaSwap Forums in the sticky's you'll find the codes.
do some more research. you might find your answer instead of waiting and hoping people respond.
get a haynes or chilton manual from autozone. it tells you how to diagnose it
i'm having the same issue, make sure you fix that or you'll end up like me having to buy a new ecu because you let it go for too long, but yeah, once you fix the idle problem and get out of limp mode, then vtec should work fine....
