Can anyone provide me with the ecu codes for Manual EG6 SIR2 with TCS year 1992?
I found a 2ndhand parts shop but I need the ecu codes.
Cause there are alot of different types of P30 out there.
Earlier I tried several p30 ecus from manual eg6 without tcs and abs. The rpm wont work. So I checked with several people,they already said , ecu without tcs cant put in eg6 with tcs or else rpm meter wont work.
https://hondaswap.com/ecu-s-electronics-tuning/help-jdm-sir-ii-tcs-problem-73502/
This guy had the same problem.
Mine is JDM MANUAL EG6 WITH TCS AND ABS.
So what ecu should I use?
