dpfi mpfi swap.. help!!!
spider
Hi! I'm doing a dpfi mpfi swap and i'm having problems, i don't know if it because of the distributor or the ecu, wire connections are all ok for sure, i've checked it a lot of times, does anyone know if the this swap works with the d16z2 distributor and pm7 ecu? i was told t only works with pm6 ecu and i don't have any. the ecu and distributor were bought apart, they are form diferent cars. the spark doesn't get to the spark plug, i've unplugged it.. can anyone help???
please...
thanks
joao
The motor and dizzy have to match, The dpfi dizzy uses a 5 wire cannon plug the MPFI dizzy uses a 7 wire cannon plug as long as the PM7 came off a car that had MPFI it should work.
digging out a post with over 2 years.. if i hadn't worked that problem with that swap already i was fu****... :D
but hey, thanks anyway! ;)
