YES OR NO?.....D-series header question
tuby
hey guys, i've been searching online and haven't found a real answer to an easy question......
ARE ALL D-SERIES EXHAUST MANIFOLD/HEADERS INTERCHANGABLE?
and.....what will fit a D16y8?
i'm not sure how but i got a crack that goes all around 1 (far left) of the header...and it's an oem stock header. and i know better than to spray water on a hot motor....any input would be great or if any of you are selling 1...stock or aftermarket but must be street legal; however i don't plan on spending over $60 on it as it is a daily driver and i just need something to stop my car from leaking air from the header...thanks.
the dohc and the sohc d series should still be the same
its been a few years for me so you might want to search around a bit on the dohc d series fit
The ports are slightly offset on the DOHC D's like so:
Otherwise than that, it will work.
Why does it matter if the ZC header will fit, he has a y8. Go to ebay and buy a header for your car, that is the only way your going to get one for <$60.
thats what it was^ i was told to enlarge the ports on the manifold,or use the plate,
but like efhonda said,,just get the header for your car,,from ebay
