GlassHeadlights
West West Yall
alright. i'm doing a mini me swap into my ef si hatch with a z6 head and a a6 block. i got it today, cleaned it up (from a wrecker) and pondered what i'm going to do with it. first i'm going to put it in without vtec to see how it runs and confirm if it needs rebuilding or not. call me what you want but i'm using a used head gasket and bolts just too see it it actually works first (i think its stupid to spend money on something that might not work). then if all goes well i'll take it apart, use a new oem z6 gasket, arp head studs and wire it for vtec. wiring vtec is mainly what i need help with. I AM A NOOB with vtec and need help along the way. i have narrowed it down too 2 desitions; use a Apexi vafc and a chip in the PM6 ecu. or a OBDO to OBDI swap. and i really don't know how to do that. if i do a OBDI swap what happens down the road if i want to put a B16 in my car? and again call me a noob if you must but can i set up a switch to a relay to set off the vtec?(temporarly of course) thanks
