I have a 93 eg hatch with a 99 B18c1. Just recently the car started sputtering.
At first it did it below 4000 rpm then that was fine then did it past 6000 rpm and now it does it continiously.
I changed the plug wires, put in NGK iridium plugs (properly gapped) and ran some seafoam through my fuel.. It cleared up only a little bit. Any other suggestions as to what could be wrong?? Would my fuel filter possibly be the problem??
Thank you for your time and advice in advance
