Go Back   HondaSwap Forums > Members' Corner > Regional Forums > Greater Michigan
Facebook Twitter
Need Aluminum Welding - Will Pay
This is a discussion on Need Aluminum Welding - Will Pay in the Greater Michigan forum
I need a catchcan welded up based on my blueprint. Blueprint will be provided to whomever accepts. It is no larger than a civic battery and only has a center division and baffles. Needs to be of decent quality, and hold mild pressure. If your ...
Old 01-25-2009, 07:17 PM   #1
YBLEGAL's Avatar
Arrow Need Aluminum Welding - Will Pay
If your interested, please let me know! This doesn't have to be local; I would pay for shipping, materials, and your time as necessary. You can respond in this thread or send me a PM.
Some help would really be appriciated!
Old 01-26-2009, 03:33 PM   #2
YBLEGAL's Avatar
Bump -
Old 01-26-2009, 03:37 PM   #3
eg6sir's Avatar
if i'm not mistaken mac24seven(sp?) might do aluminum welding.. if you cant get a hold of him, try Andrew.. its his brother in law i think
eg6sir is offline   Reply With Quote
Old 01-26-2009, 04:05 PM   #4
YBLEGAL's Avatar
No luck on mac24seven, HondaSwap Forums - Members List.
Pointed Andrew at my thread though.
Thanks for the heads up!
Old 01-26-2009, 04:30 PM   #5
eg6sir's Avatar
here ya go
HondaSwap Forums - View Profile: mac_24_seven
Old 01-26-2009, 05:27 PM   #6
Andrew's Avatar
Noted.
I'll tell terrance to get on here for you. (He'll be on tomoorrow at work)\
He's the guy to have it done, man. Thats what he does for a living (design alum fuel tanks / parts)
Old 01-26-2009, 05:31 PM   #7
eg6sir's Avatar
i knew he was good at welding... just wasnt sure if it was aluminum
Old 01-26-2009, 05:36 PM   #8
YBLEGAL's Avatar
Sweet. I've been trying to find someone with experience for a long while now. Random shops around me don't want to do it... and that's lame...
I'll be checking back frequently!
Old 01-26-2009, 05:39 PM   #9
Andrew's Avatar
Terrance doesn't actually do the welding himself. He does the blueprinting and CAD design and has it fabricated in their massive shop.
Either way, he'll get the job done, and won't charge you $5,000 for it.
Old 01-26-2009, 05:48 PM   #10
YBLEGAL's Avatar
Yay! lol.
Rep given where allowed lol
Old 01-26-2009, 06:02 PM   #11
ill do it
97hatch is offline   Reply With Quote
Old 01-26-2009, 06:05 PM   #12
eg6sir's Avatar
Andrew, didnt he make you a catch can, or was it for himself.. post some pics of the beautiness
Old 01-26-2009, 06:11 PM   #13
MthaFuknGreen's Avatar
yeah, im curious.
MthaFuknGreen is offline   Reply With Quote
Old 01-26-2009, 06:15 PM   #14
YBLEGAL's Avatar
ya some pictures of peoples work would be cool to see.
97hatch, you can do a good job? Your about 3 hours away from me http://maps.google.com/maps?f=d&sour...e=UTF8&t=h&z=9. Shall I send you the file? Estimate your price?
Old 01-26-2009, 11:17 PM   #15
autox 89 dx's Avatar
I could probly do it I'm not working right now so it could give me some thing to do. I just got laid off and and im a sheetmetal worker and I've been welding alum for the last 4 years if you want send me the drawing and ill see what I can do.Also what would you want it out of .040 or .063 ? heres a alum skylight I welded and claded in zinc
autox 89 dx is offline   Reply With Quote
Old 01-27-2009, 06:12 AM   #16
mac_24_seven's Avatar
Dude's stuff is much better though he'd probably charge more :P
I pm'd you...
mac_24_seven is offline   Reply With Quote
Old 01-27-2009, 12:46 PM   #17
YBLEGAL's Avatar
Wow nice skylight.
Alright well I might as well post it up here publicly, then we can figure out who should or will do the job.
I also don't know what thickness would be best. I think your judgment would be better than mine. Holds light pressure and sturdy, all it needs to be.
I'm also listening to any critiques anyone may have with my design.
These are just my drawings; I haven't made any architecture style drawings yet, but I need to so that they also include the bracket mounts. I'm making those up on the computer at the moment.
YBLEGAL.NET ProfileProjectsParts For SaleSteel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal
Old 01-27-2009, 01:13 PM   #18
do you have the dimensions in inches?
Old 01-27-2009, 01:19 PM   #19
YBLEGAL's Avatar
lol I was doing all the measuring in inches at first.... then idk why decided to change lol
Umm it's about 8in long, 3in wide, and 2.75in high. It could be done either way, the difference in size won't be an issue.
Old 01-27-2009, 01:21 PM   #20
YBLEGAL's Avatar
Oh I would like to add that the bottom holes are deceiving, they should have been drawn as inside as they are on the bottom for where the drain valves will go.
Based on the center divider, each side should be separate and sealed from one another, by the way. It's 2 catch cans in 1.
Old 01-27-2009, 02:49 PM   #21
Thats a breeze mang!
Old 01-27-2009, 02:58 PM   #22
YBLEGAL's Avatar
Alright. What's your cost sir?
What thickness should I go with? I'm thinking maybe thicker on the top bottom so I can thread the hose barbs and drain valves in.
And I need to get you the specs for the brackets.
To give you an idea, in my EK it's going to mount on the back of my passenger side shock tower, bolting into the tower and the place where my fuse box used to mount on the quarter panel side. I've got a battery and wire tuck so all that stuff has vacated that area.
Old 01-27-2009, 05:02 PM   #23
George777's Avatar
What exactly is it for? Battery relocation?
George777 is offline   Reply With Quote
Old 01-27-2009, 05:51 PM   #24
YBLEGAL's Avatar
It's a catch can. For doing what catch cans do. Removing toxins from the crankcase vent. Dual catch can so that it also keeps the valve cover vent clean too.
Nothing to do with battery relocation, except that it and the fusebox have been relocated, so hence that's a perfect spot for it.
Old 01-27-2009, 06:01 PM   #25
George777's Avatar
For some reason I read your original post wrong and got confused.
Pay me no mind.
welding engine pulley jaylo General Tech and Maintenance 5 03-04-2007 08:58 PM
Welding How To. TIG Welding Intro MikeBergy Body / Exterior / Interior / Cosmetics 5 07-28-2006 08:40 PM
welding classes formby Members' Lounge 10 10-13-2005 04:12 PM
Welding PSA Loco Honkey Members' Lounge 7 03-08-2004 09:47 AM
Welding eyesonlybob Members' Lounge 0 05-04-2003 05:31 PM
© 2001-2013 HondaSwap.com
