Go Back   HondaSwap Forums > Members' Corner > Regional Forums > Greater Michigan
Facebook Twitter
Need Aluminum Welding - Will Pay
This is a discussion on Need Aluminum Welding - Will Pay in the Greater Michigan forum
lol, s'all good....
Old 01-27-2009, 06:12 PM   #26
YBLEGAL's Avatar
lol, s'all good.
Old 01-28-2009, 12:02 PM   #27
YBLEGAL's Avatar
Ok, anyone want to give me their estimated costs? Since no one around me is even interested, I don't know whats reasonable. 200 bucks? Throwin that out there, lmk...
I'm still working on the blueprint. It's kind of hard to read at this point with so many lines since I was doing a transparent view, but working that out.
Old 01-29-2009, 04:37 PM   #28
autox 89 dx's Avatar
let me know when you have all the drawings done then I can figure out how much materials I'll need. As of right now I have 2 12" x12" .080 mill aluminum pieces that should be enough from the dimension you gave before. And it wont cost no 200 bucks maybe around the 60 to 80 range
autox 89 dx is offline   Reply With Quote
Old 01-29-2009, 07:23 PM   #29
YBLEGAL's Avatar
Right on right on.
Alrighty, well at this point Mac_24_seven is taking care of it, we are set to have a phone discussion Monday. But I'll keep you informed, if I need your help instead I'll defiantly let you know! He said 100 for everything minus shipping and that's cool, I expected more.
Maybe though you can help me by double checking my blueprints when they're done (I got quite a load of work without warning the last few days).
Old 01-29-2009, 09:27 PM   #30
thats cool no problem just send it and I could look it over
Old 01-30-2009, 03:51 PM   #31
Andrew's Avatar
Did you and Terrance ever talk?
Old 01-30-2009, 04:28 PM   #32
YBLEGAL's Avatar
Yes sir. And thanks again for involving him! Like I actually posted a couple posts ago, me and him are set to have a phone conversation about the details. Yayyyy I'll finally get this catch can done.... I hope... lol
Blueprints still in progress.... I'm actually at work now, but checkin up.
Old 01-30-2009, 08:02 PM   #33
Andrew's Avatar
Good deal man. GL with your car build
Old 01-30-2009, 09:42 PM   #34
awptickes's Avatar
Be sure to post lots of pictures. And the blueprints too. Remember, information should be freeeeeeeeee!
awptickes is offline   Reply With Quote
Old 01-31-2009, 02:01 PM   #35
YBLEGAL's Avatar
lol that's really fine and cooool, but I'll have to poor man's patent it, juuuuust in case.
Who knows if it will catch on.... taha
Old 01-31-2009, 02:15 PM   #36
awptickes's Avatar
You make me sad.
Old 02-07-2009, 10:46 PM   #37
YBLEGAL's Avatar
Cry through this! lol
My friend was being slow so I made it up; got some free time. Please comment/critisize. I think the baffles should perform well enough to prevent splash up and remove the contaminants from the air.
Quick discription:
The "can" is a dual chamber container. It is split directly in the center creating 2 otherwise airtight chambers. Each chamber has 2 holes on top and 1 on bottom. The bottom holes threads a valve which serves as a drain plug. The top holes serve as inlet and outlet for the vacuum system. Each hole which directly lines up with the crack in the bottom of the baffles are used for incoming flow. Each hole which is semi sheilded by a baffle is used for outgoing flow.
I will need to do a little more revising with the braketry and a level indicator. This is preliminary, so all input is welcome!
YBLEGAL.NET ProfileProjectsParts For SaleSteel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal
Old 02-09-2009, 01:23 AM   #38
it wont let me see it
Old 02-09-2009, 11:21 AM   #39
YBLEGAL's Avatar
hmm are you using Sketch Up version 7? I successfully opened this file on here at a friend's house off of this link. Obviously this is a .zip file which contains the .skp, but I'll say that anyway.
What sort of error are you getting exactly? You may need to extract the skp from the zip first.
Old 02-09-2009, 01:05 PM   #40
I got it now
welding engine pulley jaylo General Tech and Maintenance 5 03-04-2007 08:58 PM
Welding How To. TIG Welding Intro MikeBergy Body / Exterior / Interior / Cosmetics 5 07-28-2006 08:40 PM
welding classes formby Members' Lounge 10 10-13-2005 04:12 PM
Welding PSA Loco Honkey Members' Lounge 7 03-08-2004 09:47 AM
Welding eyesonlybob Members' Lounge 0 05-04-2003 05:31 PM
© 2001-2013 HondaSwap.com
