I've got an H22a4 in my 95 Accord EX. When I use a chipped P28 ECU it runs fine but only has one VTEC engagement. When I tried a P72 or P13 or P13 chipped it idles way too low and just dies out. I want to get both VTECs to engage. Anyone have any ideas?
Oh. I did read somewhere before that some wires on my ecu harness needs to be switched around to work? Something with the EGR? But I'm not sure if that is the problem at all. Thanks for any ideas or help on this. |
WRX Sellout
Ride: 2002 WRB Impreza WRX
There's no such thing as "two VTEC's". Do you mean that the IAB (secondary intake runners) is not opening? Check your wiring for that, one wire needs to be run from the IAB to the ECU (it may be two now that I think of it).
Yes, if you've got a 95 Accord, you'll need to switch pins A6 and A11 at the ECU. This will most likely fix any idling or fuel problems you're having. __________________
This space left intentionally blank. |
#10 |
thanks dohcvtec_accord, I dont even own one, but my friend does, I knwo my chassis code, just thought he'd want to know his, thanks man!
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
| Is the H22A swap worth it in an Accord? I say yes | HONDAPITSTOP | HYBRID -> BA-BB /CA-CD | 20 | 03-28-2008 01:02 PM |
| H22a4 Type-S swap | 1994HondaAccordEX | HYBRID -> BA-BB /CA-CD | 21 | 06-15-2004 09:35 PM |
| Need some accord swap info | Bump | HYBRID -> BA-BB /CA-CD | 1 | 03-28-2004 03:57 PM |
| Problems After Valvetrain Swap (long Version) | B18C_EJ8 | General Tech and Maintenance | 1 | 04-21-2003 11:42 PM |
| idle problems | slohnda | General Tech and Maintenance | 6 | 10-05-2002 01:05 AM |
