93 accord engine swap issues- from F22A6 to F22B2
Old 09-04-2009, 01:15 AM   #1
Rep Power: 1 jeepcreepcj is on a distinguished road
Default 93 accord engine swap issues- from F22A6 to F22B2
Hi, I am in the process of replacing the f22a6 engine in my 93 accord with a f22b2 from a 94 accord. The trouble I have encountered is that the ports on the head are different. I can use the b2s exhaust manifold to solve that side, but the intake manifold is a different story. I need to have the wiring harness from my f22a6 93 motor, but there is no way that I can put the manifold from my car onto the new engine, even if I modified the ports to match, the coolant hole from the head to the manifold would not align. Also, from what I have read, the head from an a motor wont fit the b because the b head is wider and one of the water jackets overhangs the block. So, is there any way I can use the manifold from the 94 in the 93? Or is there any other way to make this work? Thanks!
jeepcreepcj is offline   Reply With Quote
Old 09-06-2009, 01:33 AM   #2
Anyone?
I guess I am going to try and use the 94 manifold that fits the b2, and put my wiring harness from the 93 manifold on it. The wiring is kinda different, and the fuel line hooks up on the other side of the rail. Also none or few of the vacuum lines are going to match up.
Old 09-13-2009, 11:40 PM   #3
Well, I got it running today, Still have not done and have not worked out things like vacuum lines, power steering hose, exhaust ect. I started it for about 5 seconds so it is getting fuel the injectors are working and has spark. I need to get a new thermostat housing and a few other misc things to be able to see how well it is going to run with the mismatched manifold. If anyone is actually seeing this and reading it, is there a reason I couldn't get any replies or help? Thanks.
Old 09-25-2009, 12:34 AM   #4
Still no help... feel like I am talking to myself here.
Car ran poorly after finishing install, changed plugs and it runs much better, but still is not right. When on the throttle/under acceleration it runs good, but if maintaining a speed it seems to miss/jump around a bit, and it idles rough and low. by removing a few vacuum lines and basically allowing it to get more air the idle will pick up and smooth out. How can I correct this, does this car have an idle control valve like I read for h motors? It seems like it is just not getting enough air. Thanks for any help.
Old 09-25-2009, 12:48 AM   #5
AHHVTEC's Avatar
you shouldnt have to do anything to the new motor but drop it in and wire it up
Old 09-25-2009, 01:30 AM   #6
Thats what I understood from what I read before getting the engine, but when I started swapping them, the cylinder head is different between the two, so I had to use the exhaust and intake manifolds that came on the f22b2. I put my harness from the a6 onto the b2 manifold and it mostly plugged in. After i got it running it ran terribly, sounded worse than the old motor which had no compression in cyl 1. Guess the plugs were bad because new plugs made it run decent except for at idle and it is funny when you are driving w/out a load. It idles so low that it shakes and is rough, but creating a vacuum leak makes it idle faster and better.
Thanks for replying btw, I have not had much luck getting anyones input.
Old 09-25-2009, 01:32 AM   #7
AHHVTEC's Avatar
you dont need to swap intake manifolds, just use your stock wiring harness. and use the new motor complete/dont swap the intake manifold with the old motor. when you do that whats the problem/whats left
Old 09-25-2009, 02:38 AM   #8
low / poor idle and missing/jumpy when running without load. I will look into it some more in the evening and post up what I get. I have a different o2 sensor to try, and I am unsure if the map sensor is working properly.
Old 09-26-2009, 12:58 AM   #9
Checked some things today, and got it figured out. Because the manifolds are different, I had to lengthen and relocate some vacuum lines, the way that I had the lines to the control box/map sensor must have not allowed it to get an accurate reading.
So the initial issue was fouled plugs, and then the poor idle and surging was due to the map sensor.
Old 09-26-2009, 01:22 AM   #10
AHHVTEC's Avatar
cool glad you got it figured out
Old 09-27-2009, 06:01 PM   #11
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
Originally Posted by jeepcreepcj View Post
the cylinder head is different between the two, .
No this is wrong, they can be swapped. F22a1,A4,A6,b1,b2,F23 heads all can be mismatched. The H22 has to have work to work.
F22aX/H23 intake manifold same gasket/pattern
F22b1/2 same gasket/pattern
H22a on its own
Simply put you if your F221 came from a 94-95 accord and came with a harness you could have used that harness and everything plug up. You would then need to run the missing vtec wires from the shock tower through the firewall to the ECU.
D15Beater is offline   Reply With Quote
Old 09-27-2009, 06:36 PM   #12
My f22b2 is non vtec. I thought that the head could not be swapped with the f22a6 because there is a coolant passage that extends out of the block on the f22b2 where the a6 is flat on that spot. I must have been wrong, It would have been easier if I had known that before I swapped motors, I could have swapped the head and had everything work like the intake manifold and power steering pump mount.
92 accord best swap ( f20a , f22a6 , or f22b dohc) 92AccordJDM Accord 99 06-15-2009 01:31 AM
Prelude Accord H23a1 Intake manifold swap F22a1 F22a6 RSS-Bot Auctions 0 02-19-2008 01:33 AM
96 Accord JDM Swap Issues jdlombardozzi Accord 3 08-10-2007 12:38 PM
97 F22B2 from a LX swap in 91 accord LX dafanatic Accord 2 01-24-2007 05:02 PM
94 accord after swap issues. luis3360 HYBRID -> BA-BB /CA-CD 2 02-21-2006 03:06 PM
