I just recently swap a h22 in my f22 prelude and i was wondering if i had to add any extra vacuum hoses, if i could just use my stock f22 ones and be fine? i was told the hoses on the intake were the most important the rest were just smog issues and would not effect the cars performance
and since my car is obd1 do i need a 2nd o2 sensor? and my h22 came with a map sensor on the intake manifold and i have one from my f22 on the fire wall do i need to hook up both? anyone clear this up? |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
use one map sensor or the other
intake vac's are def most important but it would be advisable to have them all routed like stock... i believe you only need one o2 __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
#3 | |
im fixing it today just needed a few pointers i got me a diagram too |
TTIWWOP
autozone.com has a free repair section with vacuum diagrams and tons of other info...
#5 | |
vtec and knock is hooked up i am not 100% sure about the vacuum still when i get on it vtec doesnt kick in...and i cant hit my 7200 redline it bogs down after 6800 can anyone who swapped from f22 to h22 take a picture of their vacuum hoses and send em to me? it help a crap load thanks |
#6 |
Ride: 03 Avalanche
There is nothing special about the vacuum diagram. Route the vacuum hoses just like stock. Use the firewall map sensor, since your harness is already routed there. You should have one hose going to your EGR. I believe that is #16. Another hose goes to your fuel pressure regulator. You have probably three hoses coming out of your firewall that go right around the throttle body. A few more sneak around to adjust your motor mount and run your cruise control, etc.
Try checking your codes, then clear them, then check them again. The car will tell you where you messed up. __________________
-------------------- -------------------- 2003 Chevy Avalanche Leather, Moonroof, Z71, tow package, bose+six disc, nice. 1992 Accord EX (sold to good friends) JDM H22A H22A Auto Tranny w/LSD I/H/E -- All stainless w/2.5 inch Catback 1968 Oldsmobile Toronado Project car, 455 ci front wheel drive, nasty. |
#7 | |
i think i am still in limp mode my car still surges (reving from 1000-200) when idle my CEL is not on right now but i know forsure that my stuff isnt workin right i cant even get to my redline it bounces after 6800 |
#8 |
Ride: 03 Avalanche
VTEC will engage regardless of the knock sensor, so tackle each problem seperately.
Your redline is lowered when VTEC does not engage. Also, VTEC will not engage, and your redline is lowered if you rev the engine out of gear........ Use shielded audio cable for the knock sensor wire. It worked well for me, much better than standard wire. __________________
#9 | |
CEL is not on anymore either |
#10 |
TTIWWOP
are you driving the car when attempting to hit vtec?
are you letting the car warm up first? surging idle can be low coolant, tps sensor, IAC, etc... __________________
#11 | |
and yes the car is warmed up the temp gauge is at 50% |
#12 |
TTIWWOP
the first question is just as important as the second...
if tps voltage is in spec, your IAC is clean and your coolant is full and properly bled then i would check your FIT, fast idle thermo valve or some such nonsense... vtec requires a certain speed and certain operating temperature... what ecu are you running? what injectors? are you absolutely positive on your vtec solonoid and oil pressure wiring? did you try "forcing" the vtec with a 12 volt lead to make sure its definately functional? __________________
#13 | |
i had a performance shop (PRE) take a look at it they said they can fix it but it will take a few hours gonna drop it off thursday will update then for others who run into problems they said its my wiring forsure it looks like crap im gonna slap the guy who plugged in my harness |
#14 | |
TTIWWOP
how can it not work? how did you try to force it? sounds like a shop should have been in charge of your swap in the first place... ![]() __________________
#15 | |
Ride: 03 Avalanche
Don't worry about it since a shop is gonna clean up your wiring. If you're gonna fuck it up, do it yourself so that YOU can learn from fucking your own shit up. Sometimes, that's my preferred way to learn, by mistake. __________________
#16 | |
Don't worry about it since a shop is gonna clean up your wiring. If you're gonna fuck it up, do it yourself so that YOU can learn from fucking your own shit up. Sometimes, that's my preferred way to learn, by mistake. [/b][/quote] yeah i hope its just some mixed up plugs and stuff |
