Anyone out there ever put rear disc onto a 91 accord EX 4 door.What do I need off of a 92 to swap them over?Spindles?Brakelines?MasterCyli nder?obviously calipers, rotors,brackets,etc.How hard of a conversion is it I consider myself a competenet shade tree mechanic just need the info.I have heard that in some cases where a master cylinder is necessary you can simply use a proportioning valve to the rear while using the drum mas. cylinder?True/False.any info. would be appreciated as usual.
| Problem with del sol brakes | H22AdelSol | Wheels / Suspension / Tires / Brakes | 3 | 05-08-2004 12:51 PM |
| Brakes | KyleCrews | Wheels / Suspension / Tires / Brakes | 10 | 06-20-2003 11:05 AM |
| Civic Sir Brakes | IceBolt | Wheels / Suspension / Tires / Brakes | 1 | 04-19-2003 06:50 PM |
| Hf Brakes? | stud4u2c17 | General Tech and Maintenance | 1 | 03-04-2003 02:02 PM |
| brakes | Lee | Wheels / Suspension / Tires / Brakes | 5 | 10-04-2002 06:22 PM |
