Check List
Old 02-12-2006, 02:35 PM   #1
accordguy is an unknown quantity at this point
Hey guys about to do my engine swap in a week on my 95 accord ex I made a check list of everything I need for the shop to do this right please. let me know if I知 missing something however I think this list in complete.
Engine/trans and all engine mounts( mounts from accord except driver side)
ECU ( JDM p13-j01 this is the ecu I have)
Engine wiring harness (from accord)
Half shafts (accord or prelude)
Intermediate shaft (accord or prelude)
All engine accessory form the h22 drive brackets, P/S pump, alternator
Catalytic( or universal catalytic) , down pipe and header
Fuel rail from '97 or newer Prelude
Radiator hoses, heater hoses( FROM PRELUDE)
Throttle cables (for non-cruise control applications)
So here is the list is everything correct or are there things missing or items here I don稚 need to be there etc.
accordguy is offline   Reply With Quote
Old 02-12-2006, 03:41 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
reikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
look like youre all setup, just remember the mounts are not perfect and need to be altered a little bit.
also, the fuel rail can be from any H-series prelude 92+.
reikoshea is offline   Reply With Quote
Old 02-12-2006, 04:29 PM   #3
<div class='quotetop'>QUOTE(reikoshea @ Feb 12 2006, 04:41 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
thx for your input Tab what do you think looks ok
Old 02-12-2006, 11:26 PM   #4
tab
Ride:  03 Avalanche
tab is on a distinguished road
Send a message via MSN to tab
yep, PS hose is a good idea also.
Just give yourself plenty of time. You'll need something silly, and have to run to the parts store.
I'd get a nice selection of connectors, harness cover, shrink tube, solder, etc.
as always, band aids........ [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Old 02-13-2006, 07:44 PM   #5
Hey thx for your input another question do I need the prelude map or can I use my accord MAP.
Old 02-13-2006, 07:48 PM   #6
HS Troll...And Mod
reikoshea's Avatar
myspace
either or (for the map sensor) and a case of beer.
Old 02-13-2006, 09:08 PM   #7
...Hi...
HatchSpeeD's Avatar
HatchSpeeD is an unknown quantity at this point
Send a message via AIM to HatchSpeeD
[/b][/quote]
y0 B, are you sure you have to change your fuel rail to a 97+? Doesn't make any sense to me & even reikoshea says 92+...give me the link to that article dude.
HatchSpeeD is offline   Reply With Quote
Old 02-13-2006, 09:19 PM   #8
HS Troll...And Mod
reikoshea's Avatar
myspace
yeah, i used the fuel rail from my h23 on the h22. i know its 92+
Old 02-13-2006, 09:24 PM   #9
...Hi...
HatchSpeeD's Avatar
Yea I was talking to him earlier & he tells me he bought a brand new oem fuel rail from honda & cost a shit load. So I ask why'd ya do that & says that he read some article online on the h22 swap, you need a 97+ fuel rail. Didn't make much sense to me considering its a obd-1 swap going into a obd-1 chassis but ya know, gotta help my brother out & save some money $$$. If your sure on that, hopefully he return it or sell it.
Old 02-13-2006, 10:22 PM   #10
tab
Ride:  03 Avalanche
I kept the H22 rail, and modified the fuel line. Cheap and easy.
Old 02-13-2006, 10:23 PM   #11
HS Troll...And Mod
reikoshea's Avatar
myspace
yup, that works too.
Old 02-14-2006, 10:42 AM   #12
mikeislord is off the scale
<div class='quotetop'>QUOTE(HatchSpeeD @ Feb 13 2006, 10:24 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
This is probably what he read.
Dude, there is some confusion about this issue. I was prepared to swap fuel rails but it turns out not only that my F22 fuel rail didnt fit the H22, but the fuel inlet was on the correct side and I didnt need to modify it whatsoever. You can literally eyeball it for 2 seconds and figure it out. Basically, if the fuel rail inlet is on the driver's side, then the fuel line will reach. Some of the H22s I've seen have had it on the passenger side. I.E. why you would need to extend the line.
Ladies love H22.
94 Honda Accord - H22 swap, AEM V2 intake, NGK iridium IX plugs and high performance wires, custom exhaust, megan headers, jag tailights, rollin' on 16x7s
mikeislord is offline   Reply With Quote
Old 02-14-2006, 08:18 PM   #13
-94-AccordH22 is off the scale
well i know my h22 had the stock rail that was supposed to be on it. and its on the D side. and my f22 was also. so that was my easy direct replacement
-94-AccordH22 is offline   Reply With Quote
Old 02-14-2006, 09:05 PM   #14
<div class='quotetop'>QUOTE(mikeislord @ Feb 14 2006, 11:42 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Anyone knows what a prelude SRV is or what it stands for. I知 about to buy some engine parts from this guy. I want to make sure everything is compatible as long as it the same part wise as a standard prelude JDM or USDM 92-96 I知 good.
Radiator hose
Heater hose
Power steering hose
Rear engine mount and bracket
Transmission mount and bracket
Shifter assembly
Map sensor
Shifter cables
All for 250 shipped with insurance. Little pricey but I need these parts if I went to dealer I would be rapped.
Old 02-15-2006, 04:37 PM   #15
<div class='quotetop'>QUOTE(Accord Guy @ Feb 14 2006, 10:05 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Radiator hose
Heater hose
Power steering hose
Shifter assembly
Map sensor
Shifter cables
[/b][/quote]
Woah, easy partner. Unless the Accord you are swapping this into is completely scrapped and has nothing in the engine bay, you are going overboard. When I did this swap, I used my Accord PS pump and hose. Out of all those items you listed, I ended up buying one new heater hose. If the recieving car has the F22 still in it, you'll have all of that, dont need ANY of that list of stuff.
Ladies love H22.
Old 02-16-2006, 07:15 PM   #16
<div class='quotetop'>QUOTE(mikeislord @ Feb 15 2006, 05:37 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Radiator hose
Heater hose
Power steering hose
Shifter assembly
Map sensor
Shifter cables
[/b][/quote]
[/b][/quote]
LOL thx for your input however my goal though is to replace as much old stuff from my accord with prelude parts as much as possible. There are a few parts I need in this list that are a must and would be the most expensive elsewhere. For instance the engine mounts which the dealer alone wants 350 for and that just for rear and trans mount alone which are better than the accord mounts and much stiffer and the shift cables on my car are worn and they alone are 300 new and average 150 used.
Old 02-16-2006, 08:16 PM   #17
...Hi...
HatchSpeeD's Avatar
Your still gonna sell the accord & get a civic.... [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img]
Turn to the dark side....
Old 02-16-2006, 10:03 PM   #18
HS Troll...And Mod
reikoshea's Avatar
myspace
no...no...stay with us. the grass is greener.
