Compression Ratio
Old 03-25-2003, 11:52 PM   #1
Rep Power: 15 KyleCrews is off the scale
I was wondering if anyone can tell me what the stock compression ratio on a H23 prelude engine. Also what is the easiest way to bump of the compression ratio?
I took part in a Survey of 100 Men, What do men like best about a blow job
99% answered The 10 miniutes of silence
KyleCrews is offline   Reply With Quote
Old 03-26-2003, 12:02 AM   #2
I meant to say bump up the compression ratio. Sorry....
Old 03-26-2003, 12:37 AM   #3
Anything?
Old 03-26-2003, 02:15 AM   #4
Rep Power: 26 BlackJDMdeath is off the scale
Send a message via AIM to BlackJDMdeath Send a message via Yahoo to BlackJDMdeath
an easy way? replace your head gasket, honda uses a 3 piece head gasket, if you remove a layer it will bump up compression.
uhhhh... im confused with this stupid signature thingy!
BlackJDMdeath is offline   Reply With Quote
Old 03-27-2003, 01:31 PM   #5
How much would this raise my compression ratio and would it be safe to do still running stock internals? I don't want to blow this engine cuz i've only had it for about 4 months.
Old 03-27-2003, 01:58 PM   #6
Rep Power: 20 2fastaccord is off the scale
Send a message via AIM to 2fastaccord Send a message via Yahoo to 2fastaccord
The other way is just to replace the pistons with higher compression ones. It would cost you a bit more than the head gasket but you would probably want to do that at some point and time anyway.
Peace*
2fastaccord is offline   Reply With Quote
Old 03-27-2003, 04:31 PM   #7
Rep Power: 16 nuc79 is off the scale
Send a message via AIM to nuc79
The Ultimate Honda Engine Swap Guide has all of the compression ratios and hp and torque ratings.
The H23A1 is 9.8:1, 160hp, 156ft-lb. of torque. B)
My Honda Chronology: 90 Civic(traded), 88 CrxSi(totalled), 90AccordLXcpe F22A1turbo(still own, soon to be H23A1turbo), 94 GSR4dr(traded), 01Civic(traded), 89ZCsedan(traded 6/03 for 2 CRXs), 93CivicEX(sold 7/03), 99OdysseyLX(still own)
nuc79 is offline   Reply With Quote
Old 03-27-2003, 08:39 PM   #8
great advice 2fast... although you might want to add in that if you go with anything but OEM pistons you will have to sleeve your block.
Old 03-28-2003, 12:15 AM   #9
will it hurt my engine if i raise the compression ration by removing a layer of the gasket while using stock internals. I'd hate to blow it up since i just go it.
Old 03-28-2003, 01:55 AM   #10
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
I think the bottom end could handle it. However, I am not sure that you understand how hard it would be for you to replace that head gasket. It would take a long time, and a little money. Would it work, yes. Do you want to, no. The few horses that you would gain could be gained on a dyno, or with some bolt ons. Don't fool with a good thing, experiment on a shitty engine. Just my opinion.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 03-28-2003, 09:23 AM   #11
I just planned on tdoing it which I convert my h23 to vtec next month and i figured i could do it then with no trouble. Thanx for the help though guys.
Old 03-28-2003, 09:24 AM   #12
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Shit, if you're converting to VTEC anyway, why not just install some Prelude Type S pistons? 11.1:1 compression y0!
This space left intentionally blank.
Old 03-28-2003, 09:29 AM   #13
How much would those cost me and where could i get them? Also i plan on putting a head from a '97 up prelude so i can supercharge it. Can my crank and rods hold that compression ratio and boost without blowing up?
Old 03-28-2003, 10:50 AM   #14
any thoughts?
Old 03-28-2003, 01:15 PM   #15
WRX Sellout
No, I wouldn't run that compression if you're planning on boosting.
What OBD classification is your car/chassis right now?
Old 03-28-2003, 02:30 PM   #16
My car is an OBD1. Its a '94 prelude Si. Back in november i had to put another engine in it and i found a good deal an an h23 ordered from Japan. I want to put a head from a '97 up prelude so i can add a supercharger because i prefer super over turbo. I'm hoping the vtec head will swap on to my h23 block and i know i'll have to get the ECU for the '97 up and get a wiring harnes to go from OBD1 to OBD2 which is whats in the '97 up. I just dont know how easy this swap will be since i've never seen anyone else do it. Also will the instrument panel in my dash still work cuz i know the dashes in the 2 cars are very different. I know i kinda got of teh whole compreesion ratio topic but any help on these questions would be great. I can get a head from a 92-96 and 9'97 up for about the same price and pretty cheap because my friends dad owns a just yard and said he'd give me everything i needed (IM, Head, EM, ECU) and anything else for like 500 bucks. Just tryin to make a decision so i can get started.
Old 03-28-2003, 03:34 PM   #17
im not sure what all you would have to do to get that head on there, you have to remember that the 4th gen h22a has a different block design than that of the 5th gen, 4th gen being superior of course. if you plan on throwing boost at it, keep the h23 compression. ummm good luck?
Old 03-29-2003, 05:11 AM   #18
Rep Power: 16 ludeconduct is off the scale
Send a message via AIM to ludeconduct Send a message via MSN to ludeconduct
^ word, you don't want high compression with boost. Also not only are the blocks different between 4th and 5th gens but since you have a OBD1 setup, I've heard there will be issues when putting on the OBD2 head in a very recent post on hondaswap
1993 Lude Vtec
JDM H22
Lude S 5 spd Tranny
Cross Drilled Slotted all the way around
Big Mouth Bumper
CF Hood
14.92 Stock
15 flat on new engine tranny setup
ludeconduct is offline   Reply With Quote
Old 03-30-2003, 05:42 PM   #19
WRX Sellout
I think it's a pretty bad idea to try get get an OBD2 head onto an OBD1 block. BlackJDMdeath had a good point about the two different block designs (closed deck vs. open deck), and I think that's just going to give you even more headaches.
Old 03-30-2003, 06:08 PM   #20
Thanx for the advise. I think i'm just going to try to sell my h23 and swap in an H22. I think it will save me alot of time and headaches.
Old 03-30-2003, 06:17 PM   #21
WRX Sellout
compression ratio??? scottp11 General Tech and Maintenance 6 05-28-2004 03:06 AM
Static vs. Effective Compression pissedoffsol Turbo Information 0 01-12-2004 01:43 AM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
Compression Ratio iamane12d General Tech and Maintenance 21 02-26-2003 12:31 AM
compression ratio? kmcCR-Vtec HYBRID -> EG-EK / DC 2 12-23-2002 12:58 AM
