Euro R H22a Swap Is Done, But...
Old 03-24-2003, 09:04 AM   #1
Rep Power: 14 Vexamus is off the scale
My Euro R H22A runs like a Harley right now, literally, it's only firing two cylinders(180 degrees apart) so it essentially is a V twin, and with running only a straight header, it sounds just like a really really well tuned harley... pretty juicy too..
So...
To sum things up..
My fuel fittings hold for a while then start to leak.
the euro R distributor didn't have rpm signal wired up inside telling me that the Accord Euro R uses a digital ignition system and that is where the ecu get's it's rpm signal... that's fixed, now I'll have the proper fuel curve and most importantly, VTEC.
Still throwing a code, but I don't know which yet, I gotta do the diagnostic later today to see which sensor is fucked...
I'm pretty sure I have the distributor wired up correctly and I confirmed my injector wiring(the entire harness is custom).
the fuel curves are correct because even on two cylinders, that engines got some grunt. I did almost 90 last night on the way home....
I don't have powersteering anymore, I've never had a car without powersteering. I like this better, however, parking on 18's is a pain in the ass.
I still have yet to figure out how the ecu is reacting to the lack of the evap system, EGR, FIA and VTEC oil pressure switch. Right now, I'm just trying to get all the cylinders firing.
Great thing is, that after only 5 days of work(8 hour/day), we turned the key and it fired right up, very first time, no sputtering at all. Like butta!!!!
Later today, i'll post pics of some of my custom fabrication and work. And I'll begin my writeup for the swap details, this isn't anything like a regular H22A4 swap, much much more complicated. In addition to wiring issues as well... We'll see..
95 Accord Euro R Hybrid
T series 5 speed with LSD
No boost, No bottle, Pure throttle.
Accord of Doom:
Vexamus is offline   Reply With Quote
Old 03-24-2003, 09:45 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
cool man- pull those codes and figure out whats going wrong!!!
get that shizzy going
Old 03-24-2003, 10:03 AM   #3
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Awesome, great to hear. Did you teflon tape your fuel fittings to make sure they don't leak?
This space left intentionally blank.
Old 03-24-2003, 10:42 AM   #4
Rep Power: 14 LudeHatchH22a is off the scale
I take it you used the injector resistor? And why wasnt it firing on 2 cyls?
how was it more difficult then a h22 swap? I got my wires sent away to be spliced, but what else is different
dan
92 Civic hatchback.........$3000
H22a Motorswap...........$3600
Minor bolt-ons................$2000
Beating a $40,000 Corvette with a 4cyl....PRICELESS
LudeHatchH22a is offline   Reply With Quote
Old 03-24-2003, 07:46 PM   #5
ok, I need input really really bad, this is soooo frustrating...
I pulled the codes, I popped three, two were really easy fixes. the third, the CYP sensor... it's wired up correctly, shows 350ohms resistance on that sensor.
I've checked and double checked, both resistance at the ECU harness, the shock tower harness and the distributor harness, all the same....
I've checked my wiring three times, it's perfect. I'm still popping a 9 and it's firing on two cylinders.
Can someone please tell me what the specs are on that sensor on a 2001 h22a? (USDM or JDM)
Accord of Doom:
Old 03-24-2003, 08:50 PM   #6
Rep Power: 26 BlackJDMdeath is off the scale
Send a message via AIM to BlackJDMdeath Send a message via Yahoo to BlackJDMdeath
welcome to the world of a fucked cylinder position sensor... it's spreading like the fucking plague...
uhhhh... im confused with this stupid signature thingy!
BlackJDMdeath is offline   Reply With Quote
Old 03-25-2003, 08:46 AM   #7
Ok, here's what I think. After having slept on it for a bit and thought about it, it's like this....
I think since the engine is OBDIIb and the ECU is OBDI the CYP sensor has difference tolerances than what the ECU is expecting. I postulate the CYP sensor's range is 350-700 ohms(like on the F22B2). I'm betting the ECU is expecting 700-1500 ohms(like on the F22B1), so what I was hoping to do was just toss on a 400ohm resister in series with the CYP sensor, bringing the bottom measurment to 750ohms, withing the expected working range of the OBDI sensor.
Now the thing is, I'm not sure if the ECU measures the position of cyl 1 via absolute value(i.e. 700ohm = bottom, 1500 ohm=top) or relative value(i.e. minimum resistance=top, maximum = bottom, v.v.) assuming of course that the sensor will still be able to function within range.
This sensor, located in the oil pump housing on OBDII engines and in the distributor housing in OBDI engines determines the location of the 1st cylinder in order to determine ignition and injection timing. I do no believe this sensor in any way affects the fuel curve once timing has been established per cycle. That's controled by the O2, MAP, TP, and BARO sensors. This afternoon I'll try the resister trick and see what happens. If that doesn't work, I'll tear the distributor off the F22 and see if that sensor can come out and if it will fit in the place where it is on the H22A. Wish me luck.
Accord of Doom:
Old 03-25-2003, 09:21 AM   #8
WRX Sellout
Originally posted by Vexamus@Mar 25 2003, 06:51 AM
Wish me luck.
No whammies no whammies no whammies....
Old 03-26-2003, 07:05 AM   #9
Shit didn't work, sensors are too differnet, so I figured what the hell, just solve all your problems and get an OBDI distributor with external coil.
Problem solved, hauls balls, we're happy now.
Accord of Doom:
Old 03-26-2003, 09:18 AM   #10
WRX Sellout
Old 03-26-2003, 09:54 AM   #11
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
awesome y0!
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
'91 accord jdm h22a swap trev_dul HYBRID -> BA-BB /CA-CD 1 01-20-2004 12:09 PM
Got an h22a complete swap for my b-day electron-eg HYBRID -> EG-EK / DC 8 10-09-2003 04:56 PM
Help With H22A Swap DylanTheKid HYBRID -> EG-EK / DC 1 07-22-2003 07:33 PM
h22a swap bolt-ons l_toknee_l HYBRID -> BA-BB /CA-CD 15 10-27-2002 11:25 AM
worth the trouble to swap an h22a in my civic? slohnda Swap Articles 0 09-30-2002 08:38 AM
