External coil on a JDM H22?
Old 06-16-2008, 02:49 PM   #1
The Seniorest Member....
scottp11's Avatar
Ride:  93 Civic CX w/ B16A ,T3/T4 Turbo
Rep Power: 22 scottp11 will become famous soon enough
Send a message via MSN to scottp11 myspace
Default External coil on a JDM H22?
Almost finished swapping a JDM H22 into a 95 Accord, but have run into a couple of questions... The stock F22 has an external coil while the JDM H22 has an internal. I have a JDM P13 ECU. My question is, how do I wire this up? The plugs on the the JDM distributor match up to the Accord's harness, but will the car start? Do I have to get the USDM Prelude distributor and run the Accords external coil? Will the JDM ECU still run the USDM dizzy and ext. coil?
Also, there are two coolant passages located on the JDM tranny, that the USDM Accord tranny did not have. What do I do with them? Do I loop them to each other or do I have to "T" off of the coolant lines from the throttle body/head?
Anyone that can help me out would be greatly appriciated! Thanks in advance!
93civicCXB16A...T3/T4 turbo
00civicSI...CRVtec
93integraLS...GSR
scottp11 is offline   Reply With Quote
Old 06-17-2008, 12:19 AM   #2
scottp11's Avatar
Anyone? Please help!
00civicSI...CRVtec
93integraLS...GSR
Old 06-17-2008, 01:03 AM   #3
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 88 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Do the tubes come out by the VSS? If so yes they can be looped.
I need a PR3 or PW0 ECU.
Old 06-17-2008, 01:32 AM   #4
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 85 K2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud of
Send a message via AIM to K2e2vin
The coils work the same; shouldn't matter.
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 06-17-2008, 10:43 AM   #5
scottp11's Avatar
Yes, those are the ones. Thanks
00civicSI...CRVtec
93integraLS...GSR
Old 06-17-2008, 10:45 AM   #6
scottp11's Avatar
You sure? I know a friend of mine had an Accord with a JDM H22, but had a USDM P13. The shop told him he needed to buy a USDM dizzy because the UDSM P13 wouldn't run the JDM dizzy and internal coil... This shops information is what I am basing this whole discussion on...
00civicSI...CRVtec
93integraLS...GSR
Old 06-17-2008, 01:19 PM   #7
K2e2vin's Avatar
The coils are both hooked up to the ICM(which is inside both distributors), they work the same.
RIP
Old 06-18-2008, 10:27 AM   #8
scottp11's Avatar
Then what about the extra plug on the Accord harness for the external coil? Do I just leave it hanging there? It's gotta go to something, right?
00civicSI...CRVtec
93integraLS...GSR
Old 06-18-2008, 11:36 AM   #9
K2e2vin's Avatar
You could swap an external distributor there use an external coil, or use the internal coil distributor and just cut and solder the yellow and yellow/black wire together.
RIP
Old 06-18-2008, 03:04 PM   #10
scottp11's Avatar
What do I do with the other wire on the plug? I don't remember which color it is, cuzz I'm at work right now, but the plug has two wires.
00civicSI...CRVtec
93integraLS...GSR
Old 06-18-2008, 03:09 PM   #11
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 135 reikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant futurereikoshea has a brilliant future
myspace
i did this on my prelude...there is a write up here from when i first started in the honda world.
Found the answer:
on the coil plug there is a thick yellow wire...you can either cut that wire or use a spade connector and tap the top of that plug to splice it into the yellow and black wire (on the 2 wire plug) on the internal dizzy. Thats all you mess with.
Need engine Components? -- Call Us.
Tell them Fritts sent you and they will cut you a deal you will have to hear to believe.
reikoshea is offline   Reply With Quote
Old 06-18-2008, 04:06 PM   #12
scottp11's Avatar
Thank you very much!
00civicSI...CRVtec
93integraLS...GSR
Old 06-18-2008, 06:33 PM   #13
scottp11's Avatar
And the other two wires, the yel/blk and grn, I think. They don't get hooked up to anything?
00civicSI...CRVtec
93integraLS...GSR
Old 06-18-2008, 06:52 PM   #14
HS Troll...And Mod
reikoshea's Avatar
myspace
nope, thats the only mod you have to make.
Old 06-18-2008, 10:34 PM   #15
scottp11's Avatar
Alright, I looped it back like you said (the yellow wire to the black/yellow). The engine just cranks. Gets fuel, but no spark. I double checked the firing order, but when I crank it and put the spark plug wire on a ground, I get no spark. Please help! I'm soooo close
00civicSI...CRVtec
93integraLS...GSR
Old 06-19-2008, 05:38 AM   #16
HS Troll...And Mod
reikoshea's Avatar
myspace
well if i still had my prelude id take a picture of it for you.
I just know that i took the yellow wire from the coil connector and spliced it straight into the yellow and black distributor connector and my car came to life.
is the distributor known to be good.
Old 06-19-2008, 09:53 AM   #17
scottp11's Avatar
I'm stumped. I got it to crank, even sputter a time or two, but that's it. Do you have a link to that write up you did, or a link to an Accord wiring diagram? Im at work, or I'd just look at my manual.
00civicSI...CRVtec
93integraLS...GSR
Old 06-19-2008, 01:08 PM   #18
HS Troll...And Mod
reikoshea's Avatar
myspace
tab, one of the other mods here, told me about it.
check this out though...this is everything youll need for this swap.
will a JDM H22A Vtec fit in a 94' prelude "S" trim?
you might just want to check and make sure that wire is actually getting power whenever you crank the car...if so, you might need a new igniter. I think you can take the one out of an F22 distributor and use it in the H22. Im not 100% POSITIVE on that, but im pretty sure that it can be done.
Old 06-19-2008, 06:07 PM   #19
scottp11's Avatar
Okay, I'm gonna try it, but I'm pretty sure I did this last night. I'll let you know what happens... Thanks for all the help so far.
00civicSI...CRVtec
93integraLS...GSR
Old 06-19-2008, 07:45 PM   #20
scottp11's Avatar
Well, tried that. Still didn't start. Replaced the rotor and ignitor from the F22 dizzy also. Still doesn't start. I used a multimeter, and I'm getting power all the way up to the ignitor. Still no spark. Please help! Please!
00civicSI...CRVtec
93integraLS...GSR
Old 06-19-2008, 08:37 PM   #21
scottp11's Avatar
Alright, I'm getting spark on the plugs now. I put the plugs inside the plug wires and cranked the engine with a plug grounded on a bolt in the engine bay. The plugs were soaked in fuel, so I let them dry out. Lets hope this works!
00civicSI...CRVtec
93integraLS...GSR
Old 06-19-2008, 10:58 PM   #22
scottp11's Avatar
