| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | I have done a lot of research on this site, h22.org, and on the web. I have not found a good description of the wiring involved in this swap. I do have a B16a swap into a 4th gen civic under my belt, but there was a lot of info floating around about that one. I am uncertain of the ecu, but i am told it is a obd1 -the engine is from a prelude (92-97) and it is going into a 91 accord, which to my knoledge is an obd0. As far as I know, all i have to do is hook up the VTEC solenoid, Knock sensor, VTEC oil pressure switch, and oil temp pressure. But is there anything else?? If anyone can help, i would appreciate it. Thanks in advance.
__________________ 1990 Civic Hatch, B16a (Bumper fell off and Sold) 1996 Civic Hatch (d16y7 underdog build up) |
| | #2 |
| Senior Member | |
| | #4 |
| Member | if the engine is from a 92-96 prelude it is obd1 if it is a 91 accord it to is obd1 if the engine is from a 97 prelude it is obd2 then you have to get a obd1 to obd2 adapter other wise the 92-96 prelude engine will fit into the 91 accord with no problem you can use same tranny and axles just differnt ecu |
| | #5 |
| Super Moderator Join Date: Jan 2003 Location: Aberdeen, Washington State
iTrader: 0 / 0% Ride: 03 Avalanche
Rep Power: 52 | Your Accord is technically OBD 0. However, for all practical reasons, it is OBD 1. A JDM 92-96 Prelude is OBD 1. Your new ECU will plug right in to your stock harness. See the link, thanks UDT. ^^^^^^^^^ |
| H22 Wiring Options | MXDesa | ECU's, Electronics, and Tuning | 8 | 02-12-2004 12:30 AM |
| h22 in my eg, wiring problems | electron-eg | HYBRID -> EG-EK / DC | 1 | 10-16-2003 12:29 AM |
| H22 wiring | redhondahatch | HYBRID -> EG-EK / DC | 0 | 07-12-2003 10:50 PM |
| H22 In 96 Integra Wiring Help! | lineman323 | HYBRID -> EG-EK / DC | 0 | 05-25-2003 04:23 AM |
| Wiring For H23 To H22 | sly_323 | HYBRID -> BA-BB /CA-CD | 6 | 04-16-2003 05:43 PM |
