front and rear mount
Old 07-28-2003, 10:51 PM   #1
Rep Power: 0 amraccord94 is off the scale
the swap is a h22a1 into my 94 accord lx. I got everything in the only thing left is the front and rear mount. the dam thing don't line up. Im using my accord mounts do i need the prelude mounts. what am i doing wrong?
what do i do.?????????
im going by the instruction i found on a site. let me tell you im have a bone na pick with them when im done here.
amraccord94 is offline   Reply With Quote
Old 07-28-2003, 11:22 PM   #2
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 97 dohcvtec_accord is an unknown quantity at this point
Ummmm, I used my Accord mounts for the passenger side, front and rear. I know for a fact that it works. The order I did it in was passenger, front, rear, driver. Try that and see if it works.
This space left intentionally blank.
Old 07-29-2003, 03:16 AM   #3
Chicks dig the box
90 accord's Avatar
Ride:  2006 Scion xB
Rep Power: 61 90 accord will become famous soon enough90 accord will become famous soon enough
Send a message via AIM to 90 accord
it's doesn't. not don't.
i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i! i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i!i !i!i!i!i!i!i!i!i
http://www.hondashowoff.com/profile.php?id=3331 <-- my former SI
This is blue
90 accord is online now   Reply With Quote
Old 07-29-2003, 04:36 PM   #4
ok i tried it, but know i cant put in the driver side and front mount. the passinger and rear mount is in but the front and driver side mount dont fit???? was i suppost to grind down just one side of the driver side mount??
Old 07-29-2003, 04:46 PM   #5
WRX Sellout
I think it was just one side, but I'm not sure. I did it the other way, using half a driver's side Prelude mount and half an Accord side mount.
If you're using stock Accord mounts, the front, rear, and passenger side should bolt right in....
Old 07-29-2003, 04:53 PM   #6
the only prelude mount im using is the drive side
Old 07-29-2003, 04:54 PM   #7
WRX Sellout
I don't know what to tell you then, man. Post up some pictures? Make sure the mounts are installed correctly? Get a BFH?
Old 07-29-2003, 04:56 PM   #8
BFH???
Old 07-29-2003, 05:01 PM   #9
WRX Sellout
Big
Fuckin
Hammer
Old 07-29-2003, 05:07 PM   #10
ok did that.
can i go with out a front mount or is it a must that it has to go in.
Old 07-29-2003, 05:16 PM   #11
WRX Sellout
Definitely without a doubt use all 4 mounts.
Old 07-29-2003, 05:22 PM   #12
ok i got the driver side mount in with some grinding. but it fit loosely just might need washers.
i just have the front mount now, have any suggustions on what to do.
Old 07-29-2003, 05:27 PM   #13
WRX Sellout
Did the mount get bent/deformed somehow?
Did you completely tighten the bolts on the other mounts? Maybe try just setting the mounts in place and wiggling the engine around to make the front mount fit?
Old 07-29-2003, 05:32 PM   #14
ok im try it
Old 07-29-2003, 05:39 PM   #15
ok i got it in but had to use the accord front bracket.not the prelude.
Old 07-29-2003, 05:40 PM   #16
WRX Sellout
You mean for the front motor mount?
Old 07-29-2003, 05:48 PM   #17
no i mean the accord front bracket and mount.
Old 07-29-2003, 05:52 PM   #18
WRX Sellout
Ummm, I thought that's what you were doing all along. Here:
Front: Accord bracket and mount
Passenger: Accord bracket and mount
Rear: Accord bracket and mount
Driver: Either grind down the Accord mount, or use the Prelude engine-half and Accord chassis half
Did the website you were looking at not say this?
Old 07-29-2003, 06:00 PM   #19
what i did for it to work is:
accord tranny mount
prelude driver mount, grind down like hell
accord rear mount with prelude bracket. accord rear bracket didn't fit the h22 tranny.
Old 07-29-2003, 06:02 PM   #20
WRX Sellout
Strange. I used my stock Accord rear mount and bracket.
Also, don't you mean the H22 block, not tranny? I'm pretty darn sure the rear mount bolts to the block....but it's been awhile since I did the swap.
Old 07-29-2003, 06:05 PM   #21
3 bolts go on to the tranny and 1 gose ont the block. when i used the accord rear bracket the holes didn't line up to the holes on the tranny.
Forum Jump
f/s buddy club front and rear bumper brasilianstreet Parts: For Sale/Trade/Wanted 9 04-17-2004 11:03 AM
wire diagrams hcivic.com Car Audio / Security / Electronic Accessories 6 03-30-2004 02:12 AM
Tech: Engine Mount Solidification Vexamus General Tech Articles 20 02-03-2004 09:13 AM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 01:51 AM
22mm rear sway, 0mm front sway seanjuan Wheels / Suspension / Tires / Brakes 18 11-13-2003 11:57 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
