fuel injector problem
Old 07-19-2005, 11:49 PM   #1
Rep Power: 9 Supadax is off the scale
Ok i determined i had a problem with my h22 jdm injectors and removed them and put in my h23. Im pretty sure the h23 are lower volume then h22. so i am curious if i should buy stock h22 injectors off ebay or to buy the venom python injectors witht he 10% increase in flow. current setup is h22a, intake, header, a true spoon ECU not just chipped. i know the ecu maybe a problem but hey its what came with the motor. and no imediate future plans in upgrades since i just dumped 2k into this car.
problem right now is when i lay onto the throttle it chugs... im asuming not enough fuel going into the cylinders... anyways any other suggestions would be apreciated.
I may do a full fuel system upgrade high flow filter, high flow rail, pressure reg and injectors... and do the pump later on when i start needing the flow rates of higher hp.
oh and the car sat for a year before doing the swap so i think my fuel filter is clogged up anyways from sitting. but yah
thanks
Supadax is offline   Reply With Quote
Old 07-20-2005, 12:36 AM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
it is your injectors
Anime Informant
reikoshea is offline   Reply With Quote
Old 07-21-2005, 01:50 PM   #3
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
and I wouldn't bother with upgrading the fuel system UNLESS you can have the car properly tuned. EGAY chips are not tuning, they're a fuel dump with advance timing and lack of redline.
By all means buy those parts if you have the knowledge or money to properly tune the car afterward. Otherwise, just buy the stockers.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 07-22-2005, 04:18 PM   #4
Rep Power: 16 DesertNightEagle is on a distinguished road
Send a message via AIM to DesertNightEagle
Agreed, when my #1 cylinder wasn't getting fuel my lude sounded rough, and actually like an old muscle car. but it seemed like it was about to die all the time. i put in venom injectors and they work perfect now
'92 Prelude Si
H22/23 Hybrid
Port & Polished Head
Crower Stage 1 Cams
AEM Tru-Time Cam Gears
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
70mm STR Throttlebody
Golden Eagle Intake Manifold
T3/T4 Turbo
Spearco Intercooler
Tuning/turbo/Labor by JE Imports
DesertNightEagle is offline   Reply With Quote
Old 07-22-2005, 05:07 PM   #5
my ecu isnt an egay chip.. its an actuall spoon ecu... had ecu sticker on it sealing it shut and when i opened it up it was completely manufactured...
Old 07-22-2005, 05:39 PM   #6
tab
Ride:  03 Avalanche
cool.
JDM H22A
Old 07-23-2005, 01:02 PM   #7
HS Troll...And Mod
reikoshea's Avatar
myspace
Wow, thats cool....hella expensive.
Anime Informant
Old 07-25-2005, 05:22 PM   #8
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Just remember though, it's only a step above an Egay chip. Plugging a Spoon ECU into a non-Spoon engine won't necessarily help you. It's all about what mods that ECU was tuned for. It's entirely possible that the ECU is still causing some of your trouble.
This space left intentionally blank.
