H22 mounts
Old 02-10-2006, 09:43 PM   #1
Rep Power: 13 accordguy is an unknown quantity at this point
Quick question guys about to buy some OEM Honda prelude engine mounts from a 94 lude for my h22 swap in to my 95 accord ex. I don’t want to use my stock accord mounts. I’m going to buy the hasport drivers side mount. Here is my question though can I use the rest of the engine mounts except the driver side from the 94 prelude without modifying them are they a direct fit just like my accord mounts. Because someone told me I can not use none of prelude engine mounts except for the driver side unless I grind it. I need to know if i can use the other mounts for sure as a matter of fact this was his response to an ad i posted on another forum looking for the mounts.
yo all u need is the h22 side mount and u have to cut it a little bit to make it fit, but will go right in, u need to use ur stock accord trans bracket and ur stock accord back mount and stock accord trans mount and everything will go right in =]
accordguy is offline   Reply With Quote
Old 02-10-2006, 10:08 PM   #2
...Hi...
HatchSpeeD's Avatar
Rep Power: 26 HatchSpeeD is an unknown quantity at this point
Send a message via AIM to HatchSpeeD
y0 you IDIOT!! Stop being a moron & do some research!!! People like you make me sick....j/k [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img] Hey Bobby, take a look at this. Got this from H-T in a sticky.
"Attach the Accord half shaft at this point. If the engine has a Prelude half shaft remove it and use the Accord one. The Prelude one will not work. Remove the Front, Rear, and Driver side mounts from the Prelude engine. Place the Front, Rear, and Drivers mount from the Accord engine onto the Prelude engine. For the transmission, use the mount that corresponds to the tranny you are using"
Looks like your going to have to use your accord midshaft after all. If you want to, stop by & grab the one here if ya need it. I don't know how reliable that info is but if anyone has any solid info feel free. Also, does anyone know if the stock oem prelude mounts are in anyway stiffer or more heavy duty than the accord ones? I heard this & was curious if it was true or not.
BTW, this just hit me...didn't you buy the ultimate h22 guide or whatever awhile ago? If so dude, that book should cover all of this. Remember, don't let me see you on the hwy. 1.5 auto > j000 [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img]
HatchSpeeD is offline   Reply With Quote
Old 02-10-2006, 11:18 PM   #3
Rep Power: 10 mikeislord is off the scale
Werd. The hasport mount is for the driver's side mount because neither your Accord, nor the Prelude nor a 90-93 mount will work there. If you ghetto fab it like I did, be prepared for alot of vibration, its really not worth it. I'll end up buying the Hasport mount anyway come Spring when its warm again.
Ladies love H22.
94 Honda Accord - H22 swap, AEM V2 intake, NGK iridium IX plugs and high performance wires, custom exhaust, megan headers, jag tailights, rollin' on 16x7s
mikeislord is offline   Reply With Quote
Old 02-11-2006, 12:33 AM   #4
...Hi...
HatchSpeeD's Avatar
Just for clarification, aside from the hasport driverside mount...which mounts & brackets have to be used for the h22 into 5th gen accord?
Old 02-11-2006, 01:25 PM   #5
<div class='quotetop'>QUOTE(HatchSpeeD @ Feb 11 2006, 12:33 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
All the rest are 5th gen accord mounts.
Ladies love H22.
Old 02-11-2006, 09:21 PM   #6
...Hi...
HatchSpeeD's Avatar
Holy conflicting information Batman...
Old 01-18-2008, 12:43 AM   #7
Rep Power: 0 silentj845 is on a distinguished road
i want to swap my 94 accord lx from a f22 to h22 and would like to kno evrything i need for the swap hav gotten lots of print outs but am lookin for a good solid one that is correct 100% thanks
silentj845 is offline   Reply With Quote
Old 01-18-2008, 11:30 AM   #8
Rep Power: 16 powerdriverh22 is an unknown quantity at this point
Send a message via AIM to powerdriverh22
instead of being a d bag like the rest of the people who posted ill help you out....without the dbagness.
all of the prelude mounts will work. you will end up using the accord front mount. and to get the driver side prelude mount to fit you will just need to cut a little off to make it fit. dont go out and spend a bunch of money on the mount kits etc. you dont need them.
94 Accord, JDM h22a, bpi velocity stack, euro r tb, ported head, ss flat valves, s2p1 cams, bold fab header (fs), 3in exhaust
powerdriverh22 is offline   Reply With Quote
Old 01-18-2008, 11:34 AM   #9
you cant know what you are talking about if you dont think that the prelude mount wont fit.....mine did with a little help.
Old 01-24-2008, 12:53 PM   #10
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
FYI, this thread is over a year old. I don't think any of these people are even around anymore...
PSN Network ID: BrutalB83
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
