H22 Vtec Head On H23a Block
Old 05-18-2003, 01:54 AM   #1
Rep Power: 16 DesertNightEagle is on a distinguished road
Send a message via AIM to DesertNightEagle
I just wanted to know if anyone has done this or has info on it because i have a h23 and i just ordered the h22 vtec head but i heard theres an oil line from the block to the head and i need to know where the hole for the line needs to be tapped. I went to the nearest speed shop that does alot of honda's and the guy isnt too sure where it would be either since he works on mostly B16's and B18's. I was also wondering when i go to wire up the vtec portion do i just wire it to the ecu from a h22 or do i need a vtec controller/rpm switch.
'92 Prelude Si
H22/23 Hybrid
Port & Polished Head
Crower Stage 1 Cams
AEM Tru-Time Cam Gears
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
70mm STR Throttlebody
Golden Eagle Intake Manifold
T3/T4 Turbo
Spearco Intercooler
Tuning/turbo/Labor by JE Imports
DesertNightEagle is offline   Reply With Quote
Old 05-18-2003, 06:36 AM   #2
Rep Power: 26 BlackJDMdeath is off the scale
Send a message via AIM to BlackJDMdeath Send a message via Yahoo to BlackJDMdeath
there will be a... THING on the front/side of the head, it's a plugged hole, this is what you tap into on the head. you tap into the oil pressure sensor place thingy on the back of the block to feed oil to the head. you can run vtec from your vtec ecu.
uhhhh... im confused with this stupid signature thingy!
BlackJDMdeath is offline   Reply With Quote
Old 05-18-2003, 12:39 PM   #3
thanks, helps me understand a bit better, but the part where it goes into the oil pressure sensor thingy is it a hose line and need to setup a Y portion to it or is it actually part of the block
'92 Prelude Si
H22/23 Hybrid
Crower Stage 1 Cams
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
T3/T4 Turbo
Spearco Intercooler
Old 05-19-2003, 11:41 AM   #4
you will need to set up a T to it.
Old 05-19-2003, 12:23 PM   #5
Rep Power: 15 honda_mach3 is off the scale
many people when doing this setup always forget to hookup IAB. everytime someone comes to me askin why does it not running right. after numerous diagnostic, it turns out that there IAB is not hooked or the VTEC is not ground. DOUBLE CHECK. nough said.
Honda EG6 B16A2/B18C.......bring it
honda_mach3 is offline   Reply With Quote
Old 05-21-2003, 05:13 AM   #6
thanks, but right now i'm just trying to get it so that the head doesnt get messed up, obviously you can run the head with out the vtec running but if you dont hook up the oil lines right then you spent all your money on nothing
'92 Prelude Si
H22/23 Hybrid
Crower Stage 1 Cams
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
T3/T4 Turbo
Spearco Intercooler
Old 08-29-2008, 08:26 PM   #7
Ride:  91 Prelude si
Rep Power: 3 BigT91 is on a distinguished road
myspace
where did u buy ur head form online or person cuz i need a new head for my h23a block to make it vtec
BigT91 is offline   Reply With Quote
B18A1 Can I add VTEC? psychochicken HYBRID -> ED-EF / DA 9 01-19-2004 10:31 PM
H22 Head On A H23a1 Block bschilling88 Engine Building 6 03-31-2003 11:32 AM
B16 Block Ls Head, What Should I Exect? kanscrx Engine Building 9 01-18-2003 04:39 AM
B18b Head On B18a Block? Ractive78 HYBRID -> EG-EK / DC 3 01-16-2003 03:07 AM
