#1 | ||
Ride: 1992 H22A Accord EX
just got an h22 for my 92 accord. my dad is swapping it himself since i'm at college (which is a 9 and a half hour drive from where the car is). anyway, the engine is gonna be switched from a hydraulic tensioner to manual one via a parts list in an article in honda tuning magazine where they put an h22 in a civic. in the h22/civic article, they also removed the balancer belt to "free up some ponies" and my dad is wondering whether he should do the same thing or just buy a new belt and replace it. i told him that the balancers are mostly to keep the engine steady at idle, and that people with 2.5L daytonas used to disable the balancers all the time without ill side-effects (besides a little more vibration at idle, of course).
so, those of you with h22 swaps, did you disable your balancers, and if you did, have there been any ill side-effects; how's the car running and how many miles have you put on it? thanks for any help. ![]() __________________
WRX Sellout
Ride: 2002 WRB Impreza WRX
I kept my balancers and replaced the belts. I figured that it was not only for passenger comfort, but also to try to dampen engine vibration which could lead to premature engine failure.
As for disconnecting the belts....I was under the impression that it wasn't that easy. In other words, you had to buy some sort of conversion kit or something along those lines. You'd probably have to research it a little more, though. __________________
This space left intentionally blank. |
#3 | |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
![]() for the same reasons... i thought it was more to maintain an equilibrium(sp) on the internals of the engine... __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
Ride: 03 Avalanche
That's the easy belt to change. Just change it.__________________
-------------------- -------------------- 2003 Chevy Avalanche Leather, Moonroof, Z71, tow package, bose+six disc, nice. 1992 Accord EX (sold to good friends) JDM H22A H22A Auto Tranny w/LSD I/H/E -- All stainless w/2.5 inch Catback 1968 Oldsmobile Toronado Project car, 455 ci front wheel drive, nasty. |
#5 | |||
#6 | |
motor dynoed at 208 and 157 about 1000 miles ago... I have hasport mounts and no shaft in a CX civic so my car vibrates a decient amount but it it hauls ass =) __________________
EG + h22 Euro R = win |
#7 | ||
okay, i have another question: what size shielded audio wire do you reccomend to use for wiring in vtec and the knock sensor?
i didn't want to start a new thread and take up more space, so i just put my question here. thank you once again __________________
#8 |
HS Troll...And Mod
Ride: 2001 Honda S2000
i think i used 20 gauge, but mine is still going off, so i dont think you should listen to me.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
#9 |
Ride: 03 Avalanche
I used the only kind that they had at radio shack.
It's really thin, so I twisted the two wires inside togeter into one wire at each end. __________________
