H22a Cold Start Problems Please Help
Old 09-06-2006, 02:49 PM   #1
Rep Power: 12 jdmclude is off the scale
Default H22a Cold Start Problems Please Help
What's up peoples, it's been a sec since I have been on the forum. I need some guidence. I successfully swapped an h22a into my accord a couple years back. The only engine code I was throwing was EGR related. Fastfowarding to this past year. As it got cold my car did not want to start. I would take the plugs out and they would be wet from gas. I wasn't sure if some sensor on the car was telling the car to dump fuel when it didn't need to. Since then to try and correct the problem using advice and gut feelings, I replaced or rebuilt the entire distributor, coolant temp sensor, fast idle valve, spark plug wires, fuel pump, fuel filter spark plugs, oil pressure sensor, ECU and I am still having this starting issue (only when the temp begins to drop). The only known issues I know are the egr valve according to the ecu may be having some issues (low/high lift something) and I have a small crack in my exahust manifold. Both of these issues I think are separate from my starting problem. Has anyone experienced cold start issues that they were able to resolve? If so I am in dire need of help since winter will be fast approaching in months to come. Thanks Paul
jdmclude is offline   Reply With Quote
Old 09-06-2006, 02:51 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
what kinda spark plugs are you using?
i know youve done a lot, but it sounds like a spark issue to me.
Anime Informant
reikoshea is offline   Reply With Quote
Old 09-06-2006, 02:55 PM   #3
Regular NGKs the manual calls for. It can't be spark because the car starts when its not cold. I am thinking its still coolant temp issue, the sensor is not giving the ecu a correct reading which is flooding the motor since the plugs smell like straight gas once stop trying to start it. I just through it up thinking someone may have had the same issue. Thanks for the thought, but plugs have been ruled out already.
Old 09-06-2006, 03:05 PM   #4
HS Troll...And Mod
reikoshea's Avatar
myspace
did you already gap them. if the gap is wrong the engine still will start in warm weather but will have trouble starting in cold weather. the gap is 1-1.1 mms
Anime Informant
Old 09-06-2006, 03:06 PM   #5
it was my understanding that they come pre-gapped? That isn't the case?
Old 09-06-2006, 04:04 PM   #6
HS Troll...And Mod
reikoshea's Avatar
myspace
they USUALLY do, id still recommend checking the gap.
Anime Informant
H22A tranny problems thehare HYBRID -> EG-EK / DC 0 05-11-2006 07:43 PM
WTB Single Piston Rod h22 92-97 accordguy Parts: For Sale/Trade/Wanted 7 04-06-2006 11:40 PM
88 crx b18c1 w/ jrsc having start & idle problems kingmarc01 HYBRID -> ED-EF / DA 0 08-12-2004 10:04 PM
H22a With Forged Pistons W/o Resleaving JDMSpecAccordSir-T Engine Building 9 06-12-2003 10:10 PM
Reving problems h22a swap AznGurL510 HYBRID -> BA-BB /CA-CD 2 12-21-2002 11:13 PM
