H22A JDM AUTOMATIC TCM
Closed Thread
Old 01-24-2007, 06:58 PM   #26
Ride:  93 Accord Wagon
Rep Power: 7 Mulepick is on a distinguished road
p19 tcu's show up on ebay from time to time. Mostly from a guy in New Zealand. There were two sold last week for around $120.
bob
93 Accord Wagon EX
JDM h22a, mild port/polish in and out, manual belt tensioner, custom timing belt, wrapped ebay headers,
KYB AGX, Eibach springs, cai
White w/HOK Lapis Pearl
Mulepick is offline
Old 01-26-2007, 02:39 AM   #27
Rep Power: 7 AccordSE is on a distinguished road
Anyone knows the actual redline for the Auto JDM H22a motors(92-96)???
AccordSE is offline
Old 01-26-2007, 09:19 AM   #28
8k, I believe, just like the MTs
93 Accord Wagon EX
Mulepick is offline
Old 01-27-2007, 12:02 AM   #29
Rep Power: 6 1Funryd is on a distinguished road
Send a message via MSN to 1Funryd Send a message via Yahoo to 1Funryd
So, when swapping an H22 auto into another auto(honda) this particular TCU must be used or the Accord TCU?
I am researching this because I will be swapping a JDM H22 auto & tranny into my third Gen prelude, and I was thinking about the TCU, since mine is already an auto. I was thinking I would need the TCU for the JDM tranny as well, since my stock one will not know what to do with the H22 engine?
Sean
1Funryd is offline
Old 01-27-2007, 12:58 AM   #30
If you want your tranny to shift at the proper points for the h22 power band, you need the h22 auto trans and the h22 tcu (P19).
If you're sticking it in a 3 gen you may have OBD issues; make sure you check on this .
Bob
93 Accord Wagon EX
Mulepick is offline
Old 01-27-2007, 04:40 AM   #31
Rep Power: 0 H22CD is on a distinguished road
Sean
SO if I have a USDM 96-97 H22 w/ auto tranny, all I will need is a prelude TCU to make it work in a 96 Accord EX auto ? Iam confused ?!?!
H22CD is offline
Old 01-27-2007, 04:47 PM   #32
Your 96 does not currently have an h22 in it, right? So. You put the h22 in it (with the associated wiring & other changes well documented) along with the h22 ecu. If your h22 comes with auto trans, you put in the P19 h22 auto trans tcu. If you're using your Accord auto trans, leave your tcu alone, but you'll not be getting fully benefit as the Accord trans as it will shift at proper rpms for the engine that came with it (F22 prob) versus the h22.
93 Accord Wagon EX
Mulepick is offline
Old 01-27-2007, 07:31 PM   #33
Where did you get 8k from? I thought it was 7200rpm like the US 92-96 H22a Preludes...
Well, anyways, if anyone wants to buy a H22a TCU(p19), I have one for sell. Just ask me.
AccordSE is offline
Old 09-30-2007, 12:07 PM   #34
Rep Power: 0 PCWiz is on a distinguished road
Tab,
you made the comment about running one wire to the TCU. Can you tell me what and where to run this wire. I have an H22A in my Prelude with the P13 and P19 TCU with the Park lock problem.
Thanks,
PCWiz
Originally Posted by tab View Post
[img]style_emoticons/<#EMO_DIR#>/no_mike.gif[/img]
You can use either. I suggest buying the Prelude TCU. Otherwise your tranny will not shift at the proper points while in the "D" position. You may still shift manually, but the TCU won't let you shift down above a certain RPM, because it thinks you'll blow the Accord's 6200 rpm redline out of the water.
Use the Prelude TCU if you find one. Expect to wire one wire to the TCU, otherwise your shifter won't come out of park.
PS. You can still hold each gear as fast as you want.
PCWiz is offline
Old 10-04-2007, 09:34 AM   #35
Do yourself a favor. To eliminate the chances of getting the electrics wrong, gain access to the rhs of the shifter and remove a little plastic member that is in the shift linkage. It's apparent which one to take out. Throw it in the glovebox in case you want to reinstall but this solves your "shift out of park" problem.
Bob
93 Accord Wagon EX
Mulepick is offline
Old 08-20-2009, 08:54 PM   #36
Greenhorn
Rep Power: 0 accordhmongguy is on a distinguished road
djfaded1 do you still have your P19?? pm me back
accordhmongguy is offline
Old 08-20-2009, 08:56 PM   #37
Greenhorn
Default hey
do you still have the P19?? pm back
Originally Posted by djfaded1 View Post
Yeah I have P19 that works fine for sale for $200 s&H included dont need it anymore cause converted from auto to manual.
Old 08-24-2009, 10:40 PM   #38
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
This thread is two years old you moron, and the guy you're PMing hasn't been here for over 2 1/2 years. Next time, check the dates on stuff please...
PSN Network ID: BrutalB83
BrutalB83 is offline
Old 08-29-2009, 11:18 AM   #39
Greenhorn
alrite tuff guy
Old 10-02-2009, 09:33 PM   #40
Greenhorn
Rep Power: 0 axresat is on a distinguished road
This is an interesting discussion. thank you for sharing
That's pretty good.
Good post. I appreciate it
Cheap tennis ball machine for sale | Used lobster tennis ball machine | Review of Tennis twist, Playmate, Little Prince and Wilson tennis ball machines
axresat is offline
Old 10-02-2009, 09:42 PM   #41
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
alrite tuff guy
he wasn't being a dick. he was being right.
1) the guy you asked to PM you hasnt logged on these forums since January of 2007.
2) you could have PM'd him rather than bumping an old thread.
Anime Informant
reikoshea is offline
Closed Thread
