H22A Vs. H23A
Closed Thread
Old 11-12-2004, 08:06 PM   #1
Rep Power: 11 NyQuiL_AcCoRD is off the scale
Send a message via AIM to NyQuiL_AcCoRD
Thumbs up
What's up Hondaswap peoplez? Currently, I'm planning to go turbo on my H22A. I know the JDM H22A block is an open-deck, and a H23A is a slightly close-deck, which allows for higher boost. Also, the H23A is a 2.3 liter, and the H22A is a 2.2 liter. So, this is my plan:
If - H23A Block: I plan to go with a sleeve block, new low-compression pistons, rods, crank, balancing/polish, bearings, pumps, and seals. Since the H23A block is a 2.3, it has a slightly bigger displacement, but will I see a bigger gain in power verses a H22A block with the same build, but only with a 2.2 liter?
So, which block will be a better build; H22A or H23A block?
1. 95' Honda Accord EX Coupe, 1994 JDM H22A (Front-Clip), AEM Cold Air Intake, JDM Headers (JAZMA), 2.25' Test Pipe, World Sport 2 Exhaust.
2. 05' Suzuki GSX-R 1000 - ( Future Mod ) Tri - Oval Yoshumira Full-Exhaust system / Carbon Fiber.
NyQuiL_AcCoRD is offline
Old 11-12-2004, 08:20 PM   #2
Stylus DJ Extraordinaire
integraslut78's Avatar
Ride:  ?????????
Rep Power: 38 integraslut78 is on a distinguished road
Isn't a H23A a non vtec? And a H22A is a vtec motor right?
I could be wrong but I think I am right. For all motor it does not matter which motor you go with but I think boosting you would want a H22A.
I hope I am right.
DC Squad Member # 0631
I used to have my rides in this section but there are too many thieves out there trying to jack. I HATE THIEVES
integraslut78 is offline
Old 11-12-2004, 08:41 PM   #3
Rep Power: 19 hybridsol is off the scale
Send a message via AIM to hybridsol
jdm h22a is closed deck
<u>My JDM, H22, ITR, Turbo'd Integra</u> <a href=\'http://honda-tech.com/zerothread?id=831210\' target=\'_blank\'>click here!</a>
<u>project RHD sleeper hatch</u> <a href=\'http://honda-tech.com/zerothread?id=1190974\' target=\'_blank\'>click here!</a>
hybridsol is offline
Old 11-13-2004, 01:29 AM   #4
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
if your going to sleeve it, which deck it has doesnt matter, as you can sleeve it either open or closed deck. to make life easy, and still have 2.3 liters +, add a mm or 2 of overbore, and you can also use a h23 crank and rods in the h22a block. id personally run that setup- h22a block, slight overbore, h23 crank and rods. probably end up with a 2.4 or 2.5 liter motor.
handlebarsfsr is offline
Old 11-17-2004, 02:28 PM   #5
Rep Power: 49 Prowler is an unknown quantity at this point
Send a message via AIM to Prowler Send a message via MSN to Prowler
goodbye
2002 Audi A4 1.8T quatto
1995 Acura Integra GSR - H23A1
Prowler is offline
Old 11-17-2004, 03:09 PM   #6
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Originally posted by Prowler+Nov 17 2004, 12:28 PM--><div class='quotetop'>QUOTE(Prowler @ Nov 17 2004, 12:28 PM)</div><div class='quotemain'><!--QuoteBegin-hybridsol@Nov 12 2004, 07:41 PM
goodbye
[/b][/quote]
Umm, it IS closed deck.... <_<
This space left intentionally blank.
dohcvtec_accord is offline
Old 11-17-2004, 03:26 PM   #7
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 382 reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
OBD1 H22 = closed deck
OBD2 H22 = open deck
regardless of USDM or JDM..
H22 head will not bolt to H23 block easily, so there is little point in building a higher displacement block while loosing the vtec head...
there is however rumor of a H23 Vtec from either JDM or EDM, i have no idea if it exists or not, but it is said to cost about a thousand dollars more...
so if you can afford an H23 vtec then go with that, otherwise just stick with H22 head and block, OBD1 for boost, or sleeved to your choice of deck...
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline
Old 11-17-2004, 03:54 PM   #8
Rep Power: 20 b204dr is an unknown quantity at this point
Send a message via AIM to b204dr
h23a vtec is from euro r accords blue top i think and yea it is more expensive like 1000
friction created heat which creates power=does this apply in the word of automotive
b204dr is offline
Old 11-17-2004, 06:01 PM   #9
WRX Sellout
Nope.
Here's a link to a Japanese website, use your favorite website translator: http://www.honda.co.jp/HOT/ModelData/accor...-708/index.html
Here's a link to a great thread on H-T that explains alot about the different H-series engines, including the H23A, which was VTEC, and came in Accord SiR wagons ONLY, with an auto tranny ONLY (a 5-speed will bolt up, however): http://www.honda-tech.com/zerothread?id=641555
Old 11-18-2004, 09:54 AM   #10
TTIWWOP
i can't get my translator to work correctly for now...
am i seeing this correctly? the 2.3 vtec came with 4WD in the accord wagon?
and whats the HP specs for the H23A vtec
Old 11-18-2004, 09:58 AM   #11
WRX Sellout
I had trouble getting my translator to work correctly as well. I'm not exactly sure on the specs for the engine, but I believe it's still only 200 hp, and about 165 ft-lbs of torque. However, I think the slightly increased displacement allows the torque to occur a little lower.
I don't know about the 4WD aspect, but it wouldn't surprise me, since we get the junk over here in the US. <_<
Old 11-18-2004, 11:01 AM   #12
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 188 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
H23 1993-1995 Prelude Type S (JDM)
H23A1 1992-1996 Prelude SE/Si
Taken from our very own reference forum. The H23 did NOT come in the Euro R.
This post contains no personal comments or opinions; only facts.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline
Old 11-18-2004, 11:07 AM   #13
WRX Sellout
Originally posted by civicious+Nov 18 2004, 09:01 AM--><div class='quotetop'>QUOTE(civicious @ Nov 18 2004, 09:01 AM)</div><div class='quotemain'><!--QuoteBegin-b204dr@Nov 17 2004, 02:54 PM
[/b][/quote]
True, neither the H23A1 nor the H23 came in the Euro R. Only versions of the H22A came in the Euro R (the H22A7, I believe). However, if you read my link to the post on H-T, it shows that the H23A (note the lack of a trailing numeral) came in the Accord Wagon
Edit: And yes, it had a blue top.
Old 11-18-2004, 11:27 AM   #14
FüK-VTEC
civicious's Avatar
SiR = Euro R?
CMRA #265
AIM: greyfades
Old 11-18-2004, 11:36 AM   #15
WRX Sellout
Originally posted by civicious@Nov 18 2004, 09:27 AM
SiR = Euro R?
No. They're different.
The Accord Euro R had an H22A7 (DOHC VTEC, blue top). The Accord SiR had the F20B (DOHC VTEC, blue top).
Old 11-24-2004, 03:25 PM   #16
Rep Power: 16 DesertNightEagle is on a distinguished road
Send a message via AIM to DesertNightEagle
Nyquil, to answer your question in a simple form: h22/23 frankenstein is a pain in the ass. if you have a h22 already keep it and turbo it that way. watch out for certain turbo manifolds. <--- makes sure the flange for the turbo housing is more to the left side than the center cuz it'll give you problems with fitting your alternator (thats what i was having with until i we built this blocks to space the alternator out in which we'll be done with that very shortly)
edit: oh and if displacement is important to you and you have all the money in the world stick with the h22 cuz they make stroker kits that go beyond 2.3L. not sure howfar i know they go to atleast 2.4 but they might go as high as 2.6L with the stroker kit and boring. i cant remember the website anymore... if i remember i'll post it
'92 Prelude Si
H22/23 Hybrid
Port &amp; Polished Head
Crower Stage 1 Cams
AEM Tru-Time Cam Gears
AEM Power Pulleys
AEM Fuel Rail
Hondata ECU w/ P300
RC 55lb Injectors
70mm STR Throttlebody
Golden Eagle Intake Manifold
T3/T4 Turbo
Spearco Intercooler
Tuning/turbo/Labor by JE Imports
DesertNightEagle is offline
Old 07-11-2007, 04:05 PM   #17
Ride:  93 del sol SI auto to manual swap
Rep Power: 8 delsolcharlie is on a distinguished road
myspace
well if yall are looking for a H23 engine i got one sittin in the garage..no tranny..throw me some offers
delsolcharlie is offline
Old 07-17-2007, 09:22 PM   #18
Ride:  92' Prelude 4ws, H22A swapped
Rep Power: 0 rollingrock is on a distinguished road
DO YOU KNOW HOW MANY MILES ARE ON IT? WHAT ALL COMES WITH IT? I NEED ONE FOR MY 92' LUDE SI 4WS. THANKS MAN!
rollingrock is offline
Old 07-17-2007, 09:56 PM   #19
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
wow.
would this be considered thread jacking a dead thread?
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline
Old 07-18-2007, 01:08 AM   #20
myspace
its not thread jacking =P
just the engine
rebuilt only about 400 miles on it
the total engine..no ideal, supposdely everything was replaced..there was an auto tranny but i didnt want that..i actually trade my wrecked del sol...for the engine i kinda lost out..the guy that had the prelude wrecked it right after he got it rebuilt..wrapped it around a tree...passenger door was almost in the drivers seat .....yea...but if you come get it ill let it go cheap...500....400..something like that sound good
i love my honda
Old 07-18-2007, 10:54 AM   #21
Ill Give Ya 400 For It. Do You Know What Year Car It Came Out Of?
Old 07-19-2007, 06:49 PM   #22
myspace
can you come get it for 400??
i love my honda
Old 10-13-2008, 08:20 PM   #23
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Originally Posted by 95preluderacer View Post
wat up im new here and i just wanted to say that there is a jdm h23 dohc vtec its very rare its only found in jdm accord wagons.if i was you i would go for that engine it has 210 hp stock and it will smoke the hell out of the h22.im running that same engine in my prelude and it it fast.the engine is cheap its about 1800 dollars with shipping try JDMengines.corp they have that engine and many more
Check the dates before you post dude. This thread is over a year old...
PSN Network ID: BrutalB83
BrutalB83 is offline
Old 11-20-2008, 09:52 AM   #24
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 72 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
Yes there is a h23a with v-tec. It is a jdm motor it comes out of a honda accord, i thinks a 96+. It has a blue valve cover. I dont know the hp. So maybe you could get that v-tec head and ecu that would be alot less mess!!
DESPAIN is offline
Old 11-20-2008, 10:35 AM   #25
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 215 nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
nootrac22 is offline
Closed Thread
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
