H22a4 cold stall.
Old 08-21-2008, 05:37 PM   #1
Rep Power: 0 JeremyGTS is on a distinguished road
Default H22a4 cold stall.
Hey I have a 4th gen swapped with a h22a4 and it stalls when cold untill it reaches normal temp... ive cleaned IACV, running a p72 "skunk2 chipped"
ive had the ALT tested and the battery tested and they seem fine..? could this be caused by a bad ground bcasue the ground coming from my head to the frame looks coroded... aslo its hard to start i have to press the gas other wise it sounds like it wants to start up, cranks then just putters till i give it a tap of throttle...
any help would be great.
Last edited by JeremyGTS; 08-21-2008 at 05:54 PM. Reason: forgot to type "cold" after when
JeremyGTS is offline   Reply With Quote
Old 08-21-2008, 07:36 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Clean up that ground reguardless. Did you check the IACV for function? Clean and broken doesn't do you any good.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 08-22-2008, 08:07 AM   #3
good point. ill check for function. and replace if i have to.
good news is im getting my ECU tunned propperly to get that skunk2 mess outta there.
Stall and gears mylilhonda07 Civic and CRX - EF 2 02-27-2007 08:58 PM
To the guy who pooped in my stall Smarnash Members' Lounge 11 10-01-2006 03:21 AM
Strange start/stall on 90 rex BlackFrog General Tech and Maintenance 0 09-09-2004 05:26 PM
Engine Stall EG18 General Tech and Maintenance 0 06-27-2004 10:05 AM
Low Idle Stall mikoling General Tech and Maintenance 3 11-08-2003 04:08 PM
