H23 to H22 Idling problems
Old 09-07-2006, 10:34 PM   #1
the commish (h23 to h22)
Ride:  2006 Honda Civic 5spd
Rep Power: 7 hillmw is on a distinguished road
Default H23 to H22 Idling problems
I made the swap from H23 to H22 (see other threads) and went to set the idle speed by turning the screw (jumped the service connector) and there was no noticeable difference in the RPM. I turned the screw in and out about 2 full turns.
Any comments when this adjustment is made?
I'm surprised. I must have some other things going on. I was looking at my sensors and I'm thinking that there was no MAP sensor on the H23 (the vacuum hose is plugged), but the H22 may be looking for one. My manual shows all the same sensors for both the H23 and H22 but clearly there was not one on my firewall.
Is there a list of sensors that the H22 absolutely needs?
hillmw is offline   Reply With Quote
Old 09-07-2006, 11:21 PM   #2
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
There's a plug on the intake manifold(a connector) that you pull out that controls idle speed. It's the IAC(idle air control). You also need to disconnect that while adjusting the idle.
Good luck
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 09-07-2006, 11:26 PM   #3
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
map (runs like crap), tps (horrible map, runs like crap), o2 (runs like crap), crank position (dont think this causes a prob), ect (might cause some drivability problems), tdc (dont think this causes a problem), cyp (might cause a problem), iat (will cause close loop and run like crap), egr (will run crappy without), iac(might not idle right), vss (no speedo), knock sensor (will run crapy without PERIOD). most of the others dont matter.
my h23 had a map on the firewall, so im pretty sure thats where yours should be.
Anime Informant
reikoshea is offline   Reply With Quote
Old 09-08-2006, 12:08 AM   #4
yes I'm seeing that step in my procedure now, and I see my MAP Sensor connected correctly as well .... and so I'll feeling pretty lame.
H22 Cold Start Problems Please Help jdmclude Accord 1 09-06-2006 03:03 PM
h23 to h22 swap problems mtt1325 HYBRID -> BA-BB /CA-CD 4 08-28-2006 08:45 PM
H22 VTEC Problems EmEonE07390 General Tech and Maintenance 3 08-11-2006 12:00 PM
H22 Into 99 Civic Hatch. Any problems? 99civichatch HYBRID -> EG-EK / DC 2 04-05-2004 10:32 AM
H22 Problems? Zeusallmighty HYBRID -> EG-EK / DC 6 06-22-2003 12:54 AM
