I have a 2000 accord ex with 5spd. I know the tranny bolts up to the H23 but what else do i need for it to bolt in. New mounts, axles, linkage, etc.....? It is an H23 nonvtec at the moment but will soon have an H22 vtec head. Please tell me what i need to bolt it in now, i'll worry about what i need later for the head.
#2 | |
Member of the 20 nut club
do you already have the H23??? if not i would suggest waiting and saving a little more so you can just get the H22 and drop that in ... it might take a little longer but it will save you a lot of money
МОΛΏΝ ΛΑΒΈ |
#4 | |
yeah it will match up
МОΛΏΝ ΛΑΒΈ |
#6 |
WRX Sellout
Ride: 2002 WRB Impreza WRX
You'll at least need a VTEC timing belt. I'm not exactly sure what else you'd need, besides the usual VTEC head/non-VTEC block stuff (external oil line, VTEC wiring, etc).
What year is the H23? If it's 95 or older, you'll have OBD compatibility issues as well. __________________
This space left intentionally blank. |
#7 |
The engine is older than 95 but i have already solved the OBD problem. I just need to know if i need new mounts and if the tranny bolts up, from what i've been hearing, the tranny should but i havent had a definite yes.
#8 |
WRX Sellout
It should, but the reason I'm not sure is that hondaautomotiveparts.com lists the tranny casing from 93-96 Prelude VTECs as being a different parts number from the 97-02 Ludes. They LOOK the same, but the best way would be to call some local Honda dealers or Honda repair shops.
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| Decoding VIN Numbers | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:48 PM |
| Need some help with Trim Names | YangpaNemsay | General Tech and Maintenance | 7 | 08-31-2003 04:43 PM |
| All This Reference Material, And No Cel Code Chart | Slo86GT | Members' Lounge | 5 | 06-13-2003 10:31 AM |
