Ok Heres my set up.
H23 DOHC Vtec JDM Blue top 95 Lude Dizzy 95 Upper intake Manifold 96 Accord Alt, P.S., Compressor, Crank pulley JDM H22 Manual Trans (True LSD) What I'm asking is what Ecu would be the best to run this setup (OBD2). Currently I have a P5P type s ecu running but its seems that it idle higher than normal and vtec is not really there( I can Hear it but no umff) Asking for help. I got the original ecu that came this motor but I believe its AT and OBD2B connection I Have a OBD2A set up. Thanks in advance. |
This motor does not come with a knock sensor or vtec pressure swicth that the p13 would be looking for. I have no CEL displayed on the dash so I know that the current ecu does not need it. I was wondering if I need to change anything in the fuel system to compensate for the ECU (i.e. Fuel pressure regualtor, fuel pump or even fuel rail/ injectors.
Ride: dc5,mk4 gti,2nd gen civic,92 accord cp,88 crx hf
if your motor is stock then it should be fine with the ecu that you have and if there is no check engine lights then there shouldnt be anything major wrong and if it was a auto ecu there wuld be a check code
#5 |
I stated above that I don't have the stock ecu on the motor I'm using a H22 type s ecu. I know since there is no CEL there are no codes but i can;t communicate with the ecu via OBD2 connector because it does not recognize it. Any suggestions.
#7 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Wow, how incredibly insightful...
Anyway, to the OP: have you looked into a chipped and tuned ECU? __________________
#9 |
Brutal Moderator
True. I missed the part about it being OBD2. My bad...
| JDM Honda Acura FIELD VTEC FUEL Controller SFC-VTEC JDM | RSS-Bot | Auctions | 0 | 07-13-2008 11:03 PM |
| How do you wire in the VTEC solenoid in a 1997 Honda Accord LX VTEC swap? | 95ACCORDEX/LX | Accord | 0 | 07-07-2008 10:10 PM |
| APEXi Vtec vafc vafc2 Acura rsx Honda si turbo Vtec-i | RSS-Bot | Auctions | 0 | 01-06-2008 06:53 PM |
| 2000 ITR Integra Vtec head B18C5 B18C B16A LS/Vtec | RSS-Bot | Auctions | 0 | 12-24-2007 11:23 AM |
| Front Clips & Complete Swaps Dohc Vtec / Sohc Vtec | jdm_booster | Parts: For Sale/Trade/Wanted | 2 | 01-24-2004 02:47 PM |
