Ok, having idle problems with a JDM H22A swap into a 94 Accord LX (F22B2). It'll start up great, but as soon as the RPMs drop, it starts to chug and eventually dies out if left to idle on its own. I think I've checked out all the normal stuff... MAP, FIT, and TPS. Only problem I can find is that the TPS reads at almost 5 both open and closed- I can't seem to figure out how to correct that, and even them I'm not sure if it will fix the problem. Any help you have would be greatly appreciated!
