Idle high w/AC off and idle is fine w/AC on
Old 04-29-2009, 12:56 PM   #1
Rep Power: 4 thewraith is on a distinguished road
Default Idle high w/AC off and idle is fine w/AC on
Like the title says. When my A/C is on my 95 h22 accord 2 door idles fine, at about 500rpms. When I turn the A/C off, the car idles at almost 1.2k rpms. Can anyone give me a start on why this would happen? The IAC has been changed twice with no success. The VTEC valve was pretty clogged up last time I checked and was giving me idle issues (idle going up and down)- I cleaned it and the it fixed the idle moving up and down but the problem mentioned above still exists.
thanks
meek
'95 H22A Accord Coupe
'02 911 C4
'05 E500 4matic
thewraith is offline   Reply With Quote
Old 04-29-2009, 03:05 PM   #2
CAFROG's Avatar
Ride:  '92 Hatch si w/B16 (wannabe EG6)
Rep Power: 26 CAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to behold
Check the fast idle valve or the as it too can be checked/cleaned
Were you idiling at 1.2K during the winter (when A/C was obviously not used)?
Is this a new swap? If so...it could be an array of things that affect idle and such. It makes sense that your motor reacts to the A/C being turned on but not 700 rpm change.
Did you adjust idle because of the A/C (like turn it up to compensate for this drastic rpm change)?
CAFROG is offline   Reply With Quote
Old 04-29-2009, 03:12 PM   #3
The fast idle valve has been replaced and the issue didn't change. Over the winter the idle was fine, besides being erratic. There were no issues for a while but the high idle issue just started. Let me check the biss screw. I also need a vacuum diagram because I think I may have a vacuum leak. When I brake sometimes, there is a loss of pressure and I have to pump the pedal to tighten it up (or maybe just need to bleed the brakes)..
'02 911 C4
'05 E500 4matic
Old 04-29-2009, 03:35 PM   #4
CAFROG's Avatar
Brakes are seperate issue for sure.
IMO You need to get your idle in shape with A/C off
Old 04-29-2009, 03:45 PM   #5
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Have you tried resetting the ECU?
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 05-08-2009, 07:17 PM   #6
Greenhorn
Ride:  91' Accord w/ H23 Heart, 86' rolla 4ag
Rep Power: 0 PortLuver is on a distinguished road
Adjust the idle
Allow car to properly warm up (Reach proper operating temp)
When fan kicks on thats when its ready
With motor running disconect IAC valve
Turn idle screw all the way to right CLOCKWISE
give it a rev see how it reacts
slowly turn to left COUNTER CLOCKWISE till idle smooths out
Check tach to see where the idles at
When your done adjusting turn vehicle off
remove the the radio fuse wait about 10sec.
plug IAC back in and check the idle.
If it works your good money
If not check the throtle cable for to much tension
also check to see if throtle needs to be cleaned.
PortLuver is offline   Reply With Quote
Old 05-08-2009, 07:20 PM   #7
Greenhorn
As for the brake issue check for any vacuum leaks. This could be a cause of your high idle as well.
Old 05-08-2009, 11:27 PM   #8
Ride:  98 civic coupe B16A3 swap
Rep Power: 7 delcivic is on a distinguished road
on my b16 the vac hose that runs from the IM to the brake power booster has a check valve in it, as well as a direction of flow marked on it. I dont know what happens if this check valve goes bad but it might be worth looking at.
delcivic is offline   Reply With Quote
Old 09-11-2009, 12:12 PM   #9
Greenhorn
Rep Power: 0 LogicGate is on a distinguished road
I have the same problem:
93 Prelude SI (originally with h23) with Swapped JDM h22a full engine. Using m2s4 trans from h23.
New TPS calibrated
New IAC calibrated
Tested p14 (made for h23) ran perfectly. Tested p13 (made for h22a) which is made for that engine, stalled and died. P28 tuned for h22a runs but has issue original thread opener posted.
Engine stalls erratically during warm up when being accelerated. Turn A/C and other accessories and the engine does not compensate. The idle drops when accessories are turned on. No CEL lights.
LogicGate is offline   Reply With Quote
high idle!!! yagerbomb87 Prelude 2 10-17-2008 08:22 AM
Idle too HIGH.. Arrogant_ General Tech and Maintenance 3 08-10-2005 11:08 AM
High Idle khai_tuan_nguyen General Tech and Maintenance 10 07-11-2005 10:38 PM
High Idle Than Bam Irratic Idle Accordturbo94 General Tech and Maintenance 39 11-08-2003 12:22 AM
High Idle breakdancingbob General Tech and Maintenance 6 06-02-2003 09:48 PM
