Idle problems with h22
Closed Thread
Old 10-07-2003, 07:41 PM   #1
Rep Power: 33 driver1 is an unknown quantity at this point
ok im having some issues with my car not running hot enough. Fisrt of all when i start the car when it is cold it will idle up to 2500 rpm which i do beleive is to high(I think cold start idleshloud be at 1800 to 2000 if im correct). Now what happens is if i let the car idle for like a half an hr or 20 minutes anyway it will heat up to about 185 195 degrees which should be the normal operating temp i beleive. When it is at this temp it will idle right where it should at like 750 to 850 but as soon as i drive the car the temp drops to like 130 deg. to maybe 150 deg at the most, and sometimes lower than 130. Thus thwe car idles back up to like 2000 rpm again...if the temp is between 150 and 180 itll idle at like 1500. So if anyone can help, what the hellis goin on here? its getting damn annoying. anyone...
94 Honda Accord, jdm h22 swapped daily driver
04 cbr600rr fun toy
95 toyota tacoma, lifted winter truck
driver1 is offline
Old 10-08-2003, 01:06 AM   #2
Rep Power: 24 Accordturbo94 is off the scale
Have you tryed replacing the thermostate! Its a 3.50 part! Give that a whirl... ushually thats a sign... and also it will blow very cold air! It could be stuck open!
Accordturbo94 is offline
Old 10-08-2003, 09:11 AM   #3
yup already replaced it and its more like 26 bucks
04 cbr600rr fun toy
driver1 is offline
Old 10-08-2003, 12:14 PM   #4
Rep Power: 13 jdmlude92 is off the scale
did you bleed the coolant lines?
jdmlude92 is offline
Old 10-08-2003, 06:21 PM   #5
no i havent but how would that result in whats going on here
04 cbr600rr fun toy
driver1 is offline
Old 10-08-2003, 06:32 PM   #6
Rep Power: 13 ProspeedCTR is off the scale
Send a message via MSN to ProspeedCTR
Dood you must have bought the Low Temp Thermostate for that much. I only payed 2.75 for mine. If you live somewhere where it is cold all the time you may need to step up to a higher temp thermostate.
ProspeedCTR is offline
Old 10-08-2003, 07:25 PM   #7
its a 190 degree thermostat but who cares about what it is and how much i paid for it, i have a new one in there and thats all that matters. Problem lies elsewhere does anyone ahve any useful info...
04 cbr600rr fun toy
driver1 is offline
Old 10-08-2003, 07:31 PM   #8
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
besides the heating of your cockpit, the thermostat should control your engine temp, not the radiator temp. It will not open up unless the car gets to the specified temperature, even if the radiator is cold. Where are you checking the temperature at? So, even if cold ass air flows through your radiator all the time, and your radiator is at 50 degrees, your car should still warm up the engine half of the system no matter what. Your heater core is also like a little radiator. If you have that guy ripping at full speed, it could lower the temp too. Especially good to know if you're overheating, but you're the other direction.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
tab is offline
Old 10-08-2003, 07:34 PM   #9
if you don't bleed the coolant line than you can get an airbubble in the system. that can cause temperature spikes very easily. especially overheating.
Old 10-08-2003, 07:37 PM   #10
We did bleed it when we did the swap my bad so no air bubbles no temp spikes just it wont heat up unless idling thats the only time the car will get to normal operating temp. when it gets to that temp it idles where it should and the fans kick on as well i just need to know why it wont run at the right temp
04 cbr600rr fun toy
driver1 is offline
Old 10-08-2003, 11:48 PM   #11
Wow be a dick!! Your pissed cause you got ripped a new ass! Who the hell pays more than 5.00 for a thermostat! Your better off lighting your car on fire... you dont deserve it!
Old 10-09-2003, 12:15 AM   #12
ummm ya and your retarded ok? My father owns a fucking used car dealership and it doesnt matter who you are, there are alot of thermostats that are more than five dollars alright, so get a fucking life and if you dont have any helpful info for the post than dont bother. Why waste your time and mine. I guess your time might not be worht anything but i value mine
04 cbr600rr fun toy
driver1 is offline
Old 10-09-2003, 12:31 AM   #13
Rep Power: 27 IDMaxGuy is off the scale
Send a message via AIM to IDMaxGuy Send a message via MSN to IDMaxGuy Send a message via Yahoo to IDMaxGuy
have you tryed any other things or just things that have to do with the coolant system, maybe your idle is off cause of some other reason and your thermometer is reading off, it prolly is something electronic, I would take it somewhere and put in on the puter. also, i know it sounds dum but is there a good ratio of anti-freeze to water, that can fuck with temps too.
1996 Accord --- DD
1987 Chrysler Conquest--- Two Point Six liters of pure turbo fury... FURY I TELL YA...
IDMaxGuy is offline
Old 10-09-2003, 10:34 AM   #14
Your Dads dealership suxs... 88 celerbritys dont count! Good luck with your pos car! Maybe your flux capacitor is bad... have your dad fix it!
Old 10-09-2003, 10:35 AM   #15
WHAAAAAAAAAAAA WHAAA im a crying vagina!
Old 10-09-2003, 10:36 AM   #16
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
This topic has gotten out of control. There will be no further discussion / argument.
Closed by a moderator.
This space left intentionally blank.
dohcvtec_accord is offline
Closed Thread
Fixing an erratic Idle pissedoffsol General Tech Articles 2 10-22-2004 01:24 PM
HONDA IDLE PROBLEMS 92-95 CIVIC FamilyD General Tech and Maintenance 0 05-14-2004 11:07 PM
H22 Into 99 Civic Hatch. Any problems? 99civichatch HYBRID -> EG-EK / DC 2 04-05-2004 10:32 AM
H22 idle problems reckedracing HYBRID -> BA-BB /CA-CD 2 03-06-2004 07:32 PM
H22 in 93 accord idle problems reckedracing HYBRID -> BA-BB /CA-CD 1 03-04-2004 03:38 PM
