Need some accord swap info
Old 03-28-2004, 12:49 PM   #1
Rep Power: 12 Bump is off the scale
Post
I am planning on buying a 95 accord EX. 5 - speed I think it has the V-tec.
I have been searching on this board and others about this swap.
I wanted to ask is this true or not.
1. the JDM h22a ( 5-speed ) will drop right in . no motor mount moving.
2. I only have to switch the A6 ECU pin to A11 pin. to get the ECU to work.
3. only need to make some wire longer
4. I have to use the prelude Drive axles .
Is there any other info I need to do this swap?
Thanks for any help you can give.
Ps. Is there any website that are up or write ups on this swap?
What tach or cluster can I install to read the RPM/speed right?
Bump is offline   Reply With Quote
Old 03-28-2004, 03:57 PM   #2
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
1. Yes and no. The prelude transmission needs to have the mount moved a little, to a different point on the transmission. If you bolt up to your stock tranny, this doesn't apply. I've also heard that you can shave the mount slightly or frankenstein it. This doesn't apply to automatics, so I didn't have to do this.
2. If you have a 95 VTEC, you will indeed need to switch pins A6 and A11. You will also need a P13 ECU for a manual.
3. You're VTEC wires can be reused. However, you will still need to run the IAB and Knock sensor wires for an H22A. There is some harness modification required, but it's not that hard.
4. Not exactly. The Prelude and Accord Driveshafts are identical. The smaller intermediate shaft from a Prelude will need to be used.
A prelude power steering hose is helpful. If you have an external coil, you'll have to run a wire to the internal coil. Reuse your Accord emission control shit and vacuum lines. You will probably need to buy a header/downpipe combo. Your O2 sensor will be mounted down below after the swap. I bought a cheap stainless Ebay header, cleaned up the ports with a die grinder, and put it in. The O2 bung is already there, and the "prelude" header was the right length to bolt onto my stock cat.<<<<<<saves a lot of trouble.
This is a good site. We know a lot about this swap. H22A.org is under construction, or I'd send you there.
Here is My Gallery of Accord Prelude Swap pics.
You can use your stock cluster. Everything will read right. The redline will be at the wrong point for your new engine, but a guage face kit could change that.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
97 Accord swap l2ice_l2ocket HYBRID -> BA-BB /CA-CD 10 02-22-2004 03:17 AM
Detaila AKA Cam's JDM H22A Accord Swap HONDAPITSTOP HYBRID -> BA-BB /CA-CD 0 02-22-2004 01:37 AM
89 accord swap??? HatchSpeeD HYBRID -> BA-BB /CA-CD 1 09-25-2003 11:02 PM
4Th Gen H22A swap Info B20aLuDeR HYBRID -> BA-BB /CA-CD 12 07-29-2003 02:54 AM
1991 Accord Ex Swap? hrricane34 HYBRID -> BA-BB /CA-CD 3 03-07-2003 12:42 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
