My car was working perfectly fine and then all of a sudden it would lose power sometimes. you could floor it in 1st gear and then shift and it would be good until 3k then lose alotta power than gain more power at 4k and be all random.sometimes it would hit VTEC and sometimes it wouldnt. now it wont hit VTEC at all and has a 6500rpm limiter. Ive put a new distributor and spark plugs in, fixed my exhaust leak where it only has a tiny one cause of a gasket and have yet to put my fuel filter on.
I ordered the system to open up the secondaries in the intake manifold cause i dont have the box or solenoid(right now the secondaries are rigged to be open always.) Do you guys think my fuel filter might be seizing up some how and wont let fuel through? btw when it loses power ill floor it and it will be loud but it wont really go anywhere. also sometimes it will feel normal at partial throttle but when i floor it, it goes no where. thanks and sorry for the long post -nick __________________
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span> |
Ride: 03 Avalanche
sounds electrical to me. Fuel problems would not cause VTEC to engage and disengage. However, I recall something about the injectors and spark being connected somehow. Like if you lose spark, injectors don't fire, or something like that. Also, I'd double check all of your grounds and wires you connected. Did you get an engine code?
Off subject, what system did you order to open up your secondaries, and how did you make them stay open all the time right now? That might be connected with your problem. Later __________________
-------------------- -------------------- 2003 Chevy Avalanche Leather, Moonroof, Z71, tow package, bose+six disc, nice. 1992 Accord EX (sold to good friends) JDM H22A H22A Auto Tranny w/LSD I/H/E -- All stainless w/2.5 inch Catback 1968 Oldsmobile Toronado Project car, 455 ci front wheel drive, nasty. |
i ordered the vacuum tank, check valve, and two way valve from honda, i went to the junk yard and got the solenoid my self. one of the stems on my intake manifold sucks air in and i just connected that to the secondaries and it forces them open all the time.
OK finally took it to someone who knows their shit.
First of all my timing was off 7.7! thats why it was running so shitty. guy i took it to before didnt know u time preludes off the flywheel and not the crank. so i put it back to ~14.5 Second problem is that my ecu thinks my o2 sensor is broken and the VTEC solenoid so i switched the ecu out to try my friends chipped p28 and my car worked like a dream. So for $300 im getting a p28 chipped with whatever i want. spoon, mugen etc. heh i had no idea my ecu was busted. __________________
| Is the H22A swap worth it in an Accord? I say yes | HONDAPITSTOP | HYBRID -> BA-BB /CA-CD | 20 | 03-28-2008 01:02 PM |
| h23 to h22a swap problem | dubl-dee94 | HYBRID -> BA-BB /CA-CD | 2 | 06-15-2004 10:25 PM |
| PROBLEM h22a into 92 accord | digitalhav0c | HYBRID -> BA-BB /CA-CD | 4 | 05-28-2004 12:53 AM |
| H22a With Forged Pistons W/o Resleaving | JDMSpecAccordSir-T | Engine Building | 9 | 06-12-2003 10:10 PM |
| H22a Swap Problem Help! | preludejdmh22 | HYBRID -> BA-BB /CA-CD | 4 | 05-03-2003 08:11 PM |
