Facebook Twitter
Problems with my H23A1 to a H22A
This is a discussion on Problems with my H23A1 to a H22A in the HYBRID -> BA-BB /CA-CD forum
Originally posted by brian.zabrawski@qwest.com @Dec 5 2002, 10:48 AM [b]I just finished swapping out the H23A1 in my 92 prelude SI for a Jap Spec H22A1 and I'm having problems. I have added the following mods during the swap, AEM cold air intake & pulley's, ...
Old 12-20-2002, 11:18 PM   #1
Originally posted by brian.zabrawski@qwest.com@Dec 5 2002, 10:48 AM
[b]I just finished swapping out the H23A1 in my 92 prelude SI for a Jap Spec H22A1 and I'm having problems. I have added the following mods during the swap, AEM cold air intake & pulley's, Lightened Flywheel, DC header, Apexi Exhaust, B&M Fuel Guage & regulator, Hollowed out the Cat, new plugs, wires, dis cap & rotor, fuel filter, timing belt & water pump. My problem is that the car runs good till it warms up and then it bogs down bad till you hit 3 to 4 grand and it eats fuel. I've tried taking fuel out, adding more fuel, taking timing out and advancing the timing but nothing seems to work. I've trouble shot about every dam sensor, check vacumme lines and I'm about to set it on fire it's pissing me off so badly. Need help
i have the same swap as you, im experiencing the same problem...
give me a shout if you find out anything... email at loxis@shaw.ca
g2teg604 is offline   Reply With Quote
Old 12-21-2002, 10:00 PM   #2
96prelude's Avatar
i assume you have the correct ecu.
96prelude is offline   Reply With Quote
Old 12-23-2002, 03:34 AM   #3
I would over look everything once again.. mess with the air-fuel ratio u said u got a guage and pressure reg.. that might have a lil something to do with it.. and r u sure u have the right ECU.. im sure u just got a code being thrown at ya..
rmerrell is offline   Reply With Quote
Old 12-27-2002, 01:44 PM   #4
Check the 0xygen sensor. Does it idle okay all the time?
94PRELUDE is offline   Reply With Quote
Old 01-08-2003, 01:15 PM   #5
do you have a h23 ecu still in the car ?
lude22 is offline   Reply With Quote
WTB Single Piston Rod h22 92-97 accordguy Parts: For Sale/Trade/Wanted 8 08-23-2010 04:39 PM
H22A tranny problems thehare HYBRID -> EG-EK / DC 0 05-11-2006 06:43 PM
h22a into 92' accord PROBLEMS Type-T ECU's, Electronics, and Tuning 0 08-31-2004 03:51 PM
H22a wiring into H23a1 preludetypejdm ECU's, Electronics, and Tuning 2 07-30-2004 07:49 PM
H22a ECU PROBLEMS PLEASE HELPP rimsandthings ECU's, Electronics, and Tuning 2 08-05-2003 11:50 AM
© 2001-2013 HondaSwap.com
