type S internals into h22a
Old 03-07-2004, 04:34 AM   #1
jaz
Rep Power: 0 jaz is off the scale
im considering grabbin an h22a type S, but then im like what if i just get a regular
h22a w/LSD, and then buy type S pistons , cams, valves, and get p/p , that will
basically make it into a type S, am i right? can type s pistons and cams be just
simply bolted in that easily? answers and any other comments on this topic would
be appreciated and sorry if im repeating a question that may have been answered
a million times. oh and if i install those type S internals, will it matter if i use an
ECU from a type S or not ?
jaz is offline   Reply With Quote
Old 03-07-2004, 04:38 AM   #2
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
theres no way that doing all that work can be cost effective. unless a type s is several thousand dollars more than a regular h22a (its not), you'll spend way more buying the parts and then having them installed than to just buy the type s motor to begin with .
handlebarsfsr is offline   Reply With Quote
Old 03-07-2004, 04:57 AM   #3
Rep Power: 18 H22AdelSol is off the scale
i think the type-s intake manifold is bigger and doesnt have rpm based baffles either
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span>
H22AdelSol is offline   Reply With Quote
Old 03-07-2004, 10:20 PM   #4
Rep Power: 33 driver1 is an unknown quantity at this point
yes it is different its a much better design as well as not having the secodaries that open up at a certain rpmi beleive they also receive a hand port job to
94 Honda Accord, jdm h22 swapped daily driver
04 cbr600rr fun toy
95 toyota tacoma, lifted winter truck
driver1 is offline   Reply With Quote
Old 03-08-2004, 01:13 PM   #5
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
In short, just get a normal JDM H22A with an LSD tranny.
You'll be missing out on a few horsepower and a few foot-pounds of torque, and that's it. Buying most of the Type S stuff (rods, valvetrain, manifold, etc) will most definitely NOT be cost-effective for the gains you'll see. If you're really looking at upgrading your H22, get some aftermarket stuff.
However, the Type S pistons would be a decent investment, since they're more or less of a drop-in compared to aftermarket pistons, most of which require a resleeving. They'll take you up to 11.1:1 compression.
This space left intentionally blank.
Is the H22A swap worth it in an Accord? I say yes HONDAPITSTOP HYBRID -> BA-BB /CA-CD 20 03-28-2008 01:02 PM
CRX HF to Type SH H22a HondaGuy HYBRID -> ED-EF / DA 5 03-12-2004 09:49 AM
Popular Wheel / Rim Weights pissedoffsol Reference Materials 3 01-06-2004 09:55 AM
h22a or b18c (type R) Wizard45 Engine Building 15 12-21-2003 02:06 AM
type r internals civicgsr HYBRID -> EG-EK / DC 8 11-13-2002 02:27 PM
