02 Sensor wire on Air/Fuel meter turns it off?
Old 10-31-2003, 03:34 AM   #1
Sleeves+boost=Love
Ride:  91 crx
Rep Power: 18 hatchboy is off the scale
Send a message via AIM to hatchboy
Upp so the autometer air/fuel Guage works with just positive and negative wires connected but when i connect the 02 sensor wire it turns it off, what could be the deal? Its a 91 crx si with a b18b in it with b16 tranny. I am using the same o2 sensor as off of my 91 stock crx si motor (d16a6 sohc non vtec) and the same wiring harness. Could the 02 sensor not work on this car? i am getting no check engine lites besides a code 43 when i am cruisin at a steady speed (sais Fuel system) what could that be?
I rule.
hatchboy is offline   Reply With Quote
Old 10-31-2003, 10:00 AM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
i'd lean towards it being a faulty O2 sensor.
are you 100% sure it is wired properly.
pills_PMD is offline   Reply With Quote
Old 10-31-2003, 08:14 PM   #3
Sleeves+boost=Love
Ride:  91 crx
ok It was actually hooked up rite, its pre obd meaing 1 wire 02 sensor, really no way to get it wrong. It turns out that when i am at WOT there are only 2 bars on the meter showing, so it is running insainly lean. So i put a ne fuel filter in thinking mabey it was clogged. Didnt help,So i have come to the conclusion that there is just not enough fuel pressure going to the tegra engine so thats why my check engine light for the fuel system is goiong off becuase the ecu can see its running so fucking lean. So i am headed off to find myself an adjustable fuel pressure regulator and boost up that damn pressure and see what happenes.
I rule.
Old 10-31-2003, 09:58 PM   #4
Sleeves+boost=Love
Ride:  91 crx
bump suggestions>?
I rule.
Old 10-31-2003, 10:48 PM   #5
Rep Power: 14 Paperchaser013 is off the scale
get a new 02 sensor
Paperchaser013 is offline   Reply With Quote
Old 10-31-2003, 11:36 PM   #6
Rep Power: 15 thegreat1310 is off the scale
Send a message via AIM to thegreat1310
try the other o2 sensor wire
thegreat1310 is offline   Reply With Quote
Old 11-01-2003, 03:11 PM   #7
Sleeves+boost=Love
Ride:  91 crx
oh wow did you read the next post? it is pre obd, meaning only 1 wire 02 sensor. You cant get it wrong. I have the guage hooked up and the reason why i thought it wasnt working was becuase the car is rtunning so lean that it barely registers. Should i try getting a adjustable fuel pressure regulator and turning it up mabey? what do you think that would make a diF?
I rule.
Old 11-01-2003, 03:27 PM   #8
Sleeves+boost=Love
Ride:  91 crx
whats up with noone answering questions anymore?
I rule.
Old 11-01-2003, 05:18 PM   #9
my 02 has 2 wires if i had a camera id show you
Old 11-02-2003, 04:30 AM   #10
Sleeves+boost=Love
Ride:  91 crx
wow i didnt think any obd0 hondas had more then a 1 wire 02 sensor. Well update, i put on a b&m adjustable fuel pressure regulator and guage today and cracked it to 40 psi to see if it would make a dif, defenatly a lil stronger thenit was but the air fuel guage still shows very very lean and fuel system check engine light iscoming on due to the 02 sensor thinking there is no fuel going into the system i think. So i have came to the conclusion its a faulty old 02 sensor that needs to be replaced.I have replaced fuel filter allready also. So anyone have anymore ideas?
I rule.
Old 11-02-2003, 09:55 AM   #11
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
most likely the o2 sensor. With it being a 1 wire o2 i dont thing the ecu can tell if is bad or not thats probaly why its not throwing a code
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 11-02-2003, 05:50 PM   #12
Sleeves+boost=Love
Ride:  91 crx
yea on my 91 hatch si when i had an 02 sensor go out it threw an 02 sensor code. So i dont know wht the hell it could be thats making my air/fuel guage show so god damn lean.Who knows.
I rule.
A/F ratio meter rudeludenotmeanthough General Tech and Maintenance 15 09-15-2003 08:07 PM
Air/fuel Meter Vs Egt Meter JDMSpecAccordSir-T Forced Induction 5 06-19-2003 02:11 AM
