1600 to 1500 swap in 91 Civic EX non VTEC
Old 09-12-2006, 03:21 PM   #1
Rep Power: 0 papajohn51 is on a distinguished road
Default 1600 to 1500 swap in 91 Civic EX non VTEC
Friend of mine burned up his 1600, blew a bypass hose and blew head gasket. Cylinders are black and glazed...
Not sure of the correct designation, B or D,, so I'll apologize up front. I have the old engine so I can look it up and post it later if need be. Anyways he bought a JDM Twin Carbureted 1500, said thats all he could find at the time. So I figured let's try it out. So I installed the 1500 long block. Everything seemed to fit, except the 1600 had a oil cooler at the base of the filter which is not there on the 1500. Distributor on the 1500(new one) had a vacuum controlled distributor. Hmmm
I put all the intake(MPI) stuff from the 1600 on the 1500 and all seems fine... starts and runs great. except, the computer is displaying error codes for the O2 and the MAP sensors. Car will run fine on flat roads, chugs and dies on hills. New fuel filter and o2 sensor did nothing to help.
So I am wondering if someone has ever done this swap before? I wonder if I need the vacuum advance dist? Not sure at this point if I can swap the computer or??
Hopefully someone can shed some light on this problem.
Thanks in advance..
John
papajohn51 is offline   Reply With Quote
Old 09-12-2006, 09:10 PM   #2
Check your six
Ride:  86 CRX DX
Rep Power: 7 Mr.Gerbil is on a distinguished road
Are you using the vacuume advance dizzy?
You should be using the stock electronic adv. distributor because it should work with that head.
Mr.Gerbil is offline   Reply With Quote
Old 09-13-2006, 01:19 PM   #3
I am using the 1600 electronic 'dizzy' , as you call it
This engine is a D15B, was carbureted, but now has all the EFI stuff from the old 1600. I disconnected the battery, to reset the computer, because it wasnt reset after installing a new 02 sensor,, seems like it is running better. Hmmm,,
Thanks in advance..
John
CRV B20 vtec into 97 civic swap complete!!! khai_tuan_nguyen HYBRID -> EG-EK / DC 23 09-24-2009 03:39 AM
91 civic hb std jdm d1sb vtec swap 91civichbstd HYBRID -> ED-EF / DA 3 11-22-2005 08:08 PM
91 civic swap help sohc vtec help ef9vtec HYBRID -> ED-EF / DA 1 10-04-2003 05:20 PM
B18a non vtec swap into 4g civic H/b Dx streetinvader HYBRID -> EG-EK / DC 5 10-18-2002 08:23 AM
