1990 GS Best Swap option
Old 12-18-2003, 10:19 PM   #1
Rep Power: 0 Acura_GS90 is off the scale
Hey
I just bought a integra and I was wondering the best swap option for my car. I want to hit the 170 or 180 hp range. I was also wondering if you can put a 1993 gsr head on a GS b18 engine and wire up the vtec???? If it can be done and what is envolved.
Thanks
Acura_GS90 is offline   Reply With Quote
Old 12-20-2003, 11:33 PM   #2
Rep Power: 15 theB16tegguy is off the scale
First swap... just buy a b16a1 complete swap and wire vtec up and you'll be plenty happy. A few bolt ons and the 170 mark is easily made.
180hp, 113lbs of trq. ... more than enough to make an ass out of you and your stock 04 silverado.
theB16tegguy is offline   Reply With Quote
Old 12-21-2003, 03:19 PM   #3
_Keith_'s Avatar
Rep Power: 13 _Keith_ is off the scale
just keep the ls engine and go turbo.
_Keith_ is offline   Reply With Quote
Old 12-21-2003, 06:36 PM   #4
ummm...... NO. Unless u know what ur doing.
Old 12-21-2003, 07:47 PM   #5
Rep Power: 0 H9Omega is off the scale
If you have the funds to go with another swap i suggest going with a GSR or even a Type R but that all depends on you. If not the LS motor has plenty potential, i just personally wouldn't go with a b16..
H9Omega is offline   Reply With Quote
Old 12-21-2003, 07:49 PM   #6
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
i just personally wouldn't go with a b16..*
neither would I
If i were u i would turbo the LS, b16 would actually be a downgrade IMO, i know youll ask why so I'll answer now
1) 1.8>1.6
2) Torqueyer
3) IMO a better starting platform (you have many different things you can do with it)
4) It will be cheaper
5) You already have the engine
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 12-21-2003, 11:28 PM   #7
_Keith_'s Avatar
Originally posted by theB16tegguy+Dec 21 2003, 06:36 PM--><div class='quotetop'>QUOTE(theB16tegguy @ Dec 21 2003, 06:36 PM)</div><div class='quotemain'> <!--QuoteBegin-_Keith_@Dec 21 2003, 03:19 PM
ummm...... NO. Unless u know what ur doing. [/b][/quote]
wtf?
Dont go high boost! And dont take much knowledge to do a turbo.
Old 12-21-2003, 11:41 PM   #8
Ride:  DC2 ITR and DC4 LS
Rep Power: 19 Gen2Teg is off the scale
Send a message via AIM to Gen2Teg Send a message via Yahoo to Gen2Teg
a B16 in an integra is worthless. Might as well put a D15 in there and call it a day. Theres NO torque at all and the high end power doesn't help once you're already 6 cars behind the other guy. Its not even like its a big ammount of high end power anyways. Don't listen to anyone who tells you to get a B16 into any integra, especially 2nd gen 90-91 integras because people think its so easy to do since its OBD 0 too. If you want VTEC, go LS/VTEC or get a GSR or ITR motor in there. All you would need then is a OBD 0 VTEC distributor and a PR3 ecu. If you wanna have 170-180hp, i'd go with a GSR motor. Depending on how an LS/VTEC motor is built, a GSR can be more stable. Just drop that in there with your basic bolt-ons and you'll be happy. Just remember this: There is NO replacement for displacement.
Gen2Teg is offline   Reply With Quote
Old 12-22-2003, 01:54 PM   #9
Rep Power: 0 argetni is off the scale
i agree with everyone you could do a swap here are some choices
Engine: 1988-1991 JDM B16A
Displacement: 1595cc
Compression Ratio: 10.2:1
Hp/Torque: 160hp@7600rpm/112lb-ft@7000rpm
Transmission: JDM S1, J1, Y1, A1 (cable
Engine: 1992-up JDM B16A
Compression Ratio: 10.4:1
Hp/Torque: 170hp@7800rpm/116lb-ft@7300
Transmission: Y21, S4C (hydraulic)
Engine: 1994-1995 USDM B18C1
Displacement: 1797cc
Compression Ratio: 10.0:1
Hp/Torque: 170hp@7600rpm/128lb-ft@6200
Transmission: Y80 (hydraulic)
Engine: 1996-up JDM B18C
Compression Ratio: 10.6:1
Hp/Torque: 180hp@7600rpm/129lb-ft@6200
Transmission: Y80, S80 (hydraulic/optional LSD)
Engine: 1997-up USDM B18C5
Hp/Torque: 195hp@8000rpm/130lb-ft@7500rpm
Transmission: S80 w/ LSD (hydraulic)
or you could do a turbo or a lsvtec biuld but to do either of these right you need to go thru the motor and once you go thru and replace pistons and rods and bearing and gaskets so that you know that you have a reliable motor you could of done a swap and had money to spare . the reason everyone does a b16 swap is b/c they are pretty cheap you can get a half cut from japan that would have everything you need b16 trany ecu wiring all for 1600$ so it is up to you on what you what to do . also 90-91 b18a 130hp 92-93 140 hp this is b/c the intake manifold flows better in the 92-93 models.
argetni is offline   Reply With Quote
Old 12-22-2003, 02:00 PM   #10
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
i have a b16 im my 90 teg and have no problems beating most things on the street.
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
Old 12-27-2003, 10:53 AM   #11
Alright
Thanks for the info. My engine has 330 kms on it so it is going to have to be replaced anyway and i was just wondering where I should start.
Info on a JDM B16A SiR2 swap into a 96 Civic DX spektrum HYBRID -> EG-EK / DC 9 04-27-2008 08:46 PM
Who ever completed a ZC swap in CRX Si KYL174 HYBRID -> ED-EF / DA 6 04-09-2007 10:34 PM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
FS: 1990 rex crx SI /b16a swap for cheap! mellowboy Vehicles: For Sale/Trade/Wanted 1 11-04-2003 03:00 AM
Which B-series Engine Is The Best To Swap? gupta_p HYBRID -> EG-EK / DC 12 02-05-2003 09:16 PM
