1991 crx with 94 d15b7 please help!
Old 10-17-2009, 09:29 PM   #1
Greenhorn
Ride:  1991 Honda CRX d15b7 :(
Rep Power: 0 streetlethal4024 is on a distinguished road
Send a message via AIM to streetlethal4024 myspace
Question 1991 crx with 94 d15b7 please help!
first off let me say whatsup to everyone as this is my first post on this forum i deff plan on posting way more, seems like the good forum for help
but now on to my car, I have a 1991 Crx that i got a few months ago the guy i purchased it from said it used to have a gsr motor in it but he bought it as a shell, and for some dumb reason he swapped in a 94 d15b7 with dpfi this i know because i found the stamp.
now the problem... i want to swap the motor out for a d16y8 or similar motor now my check engine light is on but idk if it is obd1 or obd0 and i dont know what ecu is in my car.
so my question is how can i figure our what obd my car is and what ecu is in it? and if they will work with the d16y8 and if not what i need to make it all work, also i was wondering if there was a way to find out what tranny is in my car as well?
the motor in my car is blowing serious smoke and it is my daily driver so i am going to have to do something soon. and sorry if this post doesent make sense im really really confused on whats going on in this car
thanks in advance for all ur help
streetlethal4024 is offline   Reply With Quote
Old 10-17-2009, 10:19 PM   #2
yeah, it's a vtec.
c-rex-beat's Avatar
Ride:  89 crx/z6
Rep Power: 4 c-rex-beat is on a distinguished road
myspace
look in passenger footwell for maybe a metal plate. behind there is the ecu. if it has a small glass "peep" it's obd0. on side of ecu is a label. what are the middle 3. like pm6, p28, p2p.
c-rex-beat is offline   Reply With Quote
Old 10-17-2009, 11:14 PM   #3
Greenhorn
thanks so much for your responce. it has the glass peep with a red led that flashes, and the label says 37820-pm5-a09 there is also a blue stamp that says 90.30.02. so i am guessing it wont work with the d16 because it is obd0 and the d16 is obd1? how would i make them work together? sorry im pretty new with hondas and im desperate to make this crx quick the two injector wonder sucks. is there a better easier swap to do?
Old 10-18-2009, 01:22 PM   #4
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
Thats the stock D15B2 ECU, as long as the DPFI intake manifold is in place it should be fine. Count the blinks on the ECU, that will tell you the problem.
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is offline   Reply With Quote
Old 10-18-2009, 04:32 PM   #5
Greenhorn
which ecu is the best to run with a y8?
Old 10-18-2009, 05:26 PM   #6
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
first suggestion ditch that y8 idea. obd2 is no fun. go with a z6 unless you plan to port or upgrade the oil pump on your y8. They suck bad. but if you insist the best ecu for the y8 is the p2p but you can run a stock p28 with a jumper harness with no problems. y8 is obd2 by the way z6 is obd1.
philyphreak2127 is offline   Reply With Quote
Old 10-18-2009, 06:46 PM   #7
Greenhorn
is it easier to swap to obd1?
Old 10-18-2009, 07:22 PM   #8
Ride:  1991 civic hatch dx
Rep Power: 5 Bobby17772 will become famous soon enough
what you would need to convert to obd1
obd0 to obd1 conversion harness
obd1 distributor (make sure its one that fits your engine)
obd1 ecu (make sure its one that will work with your engine and trans, auto or manual)
4 wire heated O2 sensor (preferably one with Honda connectors)
obd0 engine harness
Bobby17772 is online now   Reply With Quote
Old 10-18-2009, 08:44 PM   #9
SOHC on this!!
Yes, I don't know anyone who would choose OBD2 over OBD1 when it comes to tuneing and ease of swap. Even OBD2 guys "downgrade" to OBD1 so they can tune.
So...P28 ECU. Most common in the Honda world.
Old 10-19-2009, 10:40 AM   #10
Greenhorn
thanks and this guy i know has a d15b7 that doesent blow smoke and this other kid i kno has a z6 head so could i use the b7 bottom end with the z6 head and use the p28 after swapping to obd1?
Old 10-19-2009, 01:14 PM   #11
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
I know its been resolved but wouldn't dpfi point out that it as obd0...? just for future reference.
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 10-19-2009, 05:38 PM   #12
SOHC on this!!
Yeah that would work fine.
Old 10-21-2009, 11:34 PM   #13
Greenhorn
thanks so much thats my new plan any good suggestions for what kind of adjustable cam gear i should get to zero out the timing?
Old 10-22-2009, 12:56 AM   #14
SOHC on this!!
AEM makes a great gear, some say they've found great eBay products.
need some info about a simple d15b7 to d15b7 swap jdovel21 Civic and del Sol - EG and EK 4 03-28-2008 02:39 PM
DSM 16G on a D15B7 knuteiriktveiten Forced Induction 3 02-11-2008 02:15 PM
d15b7 $ solerizr General Tech and Maintenance 3 10-26-2006 03:12 AM
d15b7 thegreat1310 HYBRID -> ED-EF / DA 1 11-07-2005 06:11 AM
Del Sol 94 1.5 D15b7 microfreak22 General Tech and Maintenance 1 06-03-2003 05:58 AM
