4-Speed/5-Speed SI Transmission HELP
Old 07-04-2009, 07:55 PM   #1
Rep Power: 1 Draftinwitjr3815 is on a distinguished road
Default 4-Speed/5-Speed SI Transmission HELP
Ok, I am looking to figure out which Transmission will be best for what I'm trying to do.
Basically I have a 90 Civic DX Hatchback with a stock D15B2 and 5spd trans.
I have a 4spd trans out of a 90 Civc DX and a 5spd trans out of a 90 CRX Si sitting on the floor.
What I need to figure out is the Final Drive ratio's and gears that are in these transmissions
I am going to race it on a 3/8 mile asphalt oval track here in NY and I need the trans with the longest 3nd and 3rd gear
I can't find ANY information on the gearing in the 4spd, and I haven't had much luck locating any info on the stock 5spd.
Any help would be greatly appreciated, thanks!
Draftinwitjr3815 is offline   Reply With Quote
Old 07-05-2009, 02:19 PM   #2
SOHC VTEC at its best
95EGCoupeVtec's Avatar
Ride:  95 Civic EX Coupe
Rep Power: 6 95EGCoupeVtec will become famous soon enough
myspace
what u should do is sell me that crx si tranny. i need one for a swap like really bad. the d15b2 will have longer gears. the si tranny has shorter gears obviously for acceleration.
the si tranny has a 4.25 final drive. idk about the 4 spd.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R
Xenocron chipped ecu
Greddy Type RS bov
Tial 38mm WG
GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
LSD motorsports race PP with 6 puck sprung disc
Soon to have:
aluminum rad/fan/T-stat combo from GoAutoworks
Competition Clutch Stg5 w/4puck disk
tune by Darren in Baton Rouge, LA
95EGCoupeVtec is offline   Reply With Quote
Old 07-05-2009, 04:35 PM   #3
jlicrx's Avatar
ZCspeed Racing
Old 07-05-2009, 09:43 PM   #4
One question about that chart ^^^^^Above^^^^^
The smaller the number the longer the gear correct???
So I would favor a 4 spd trans because 2nd and 3rd gears are longer?
Perfect, just the info I wanted!!! Thanks!
Also, that trans is going to cost at least $100 to ship to you, not even sure where your located, so its not worth me selling it for only $50....
Old 07-05-2009, 10:45 PM   #5
ambitious...but rubbish
hatukazi's Avatar
Ride:  91 Si hatch GSR swap
Rep Power: 17 hatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the rough
myspace
I might be wrong, but you may need different axles to run the 4 speed trans. even if you'd want to.
I live my life a quarter mile at a time, thats how far I get before I break down.
hatukazi is offline   Reply With Quote
Old 07-06-2009, 12:51 PM   #6
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
Rep Power: 17 HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
my si trans effed up and i swapped a 4spd in ..used the same axles
admit it..your a ricer....
90 si hatch jdm d15b swap(done)
91 dx hatch b16 swap (in progress)
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
stage 3 act clutch ftw
HATCHET_HONDA is offline   Reply With Quote
Old 07-06-2009, 03:06 PM   #7
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 20 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
HF is the only one with different axles. It has a different spline count on the hub, or was it to the transaxle.. I forget..
PSN: Korax37
Korax is offline   Reply With Quote
Old 07-06-2009, 04:23 PM   #8
myspace
i'm located at 39466, how much do u want for it? lemme konw i need it for a d15b swap into a 90 civic hatch. thx
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Greddy Type RS bov
Tial 38mm WG
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Soon to have:
Old 07-06-2009, 04:39 PM   #9
Greenhorn
Ride:  91 CRX, 89 Honda Hawk
Rep Power: 0 ahknodd is on a distinguished road
The HF has the same axles as the Standard Civic. The DX has the bigger outter hubs as the Si but the inner seal part on the tranny are different betweent he Dx and Si, so STD/HF axles are the same, DX are different, and Si are different.
If you're racing oval I would think the DX would be best for you. As you can see in the chart the actual gears in the DX and Si are the same, the final drive is what makes the Si the most desireable for most people. The final drives are the same in the 4 speed and the DX, but I would think you'd want a bit of lower acceration. The 4 speeds are complete pigs. Yet if you're looking for the longest 3rd gear then look for an HF tranny.
ahknodd is offline   Reply With Quote
Old 07-06-2009, 04:55 PM   #10
Thanks for everyone's help, I think I'm going to stick with the DX 5spd after all.
As for the SI tranny I have, I've got a guy locally willing to pay $250 for it, so if you can beat that, remember to include shipping from 14212 to you.
Thanks again guys!
Old 07-06-2009, 09:21 PM   #11
myspace
hmm.....so $250 plus shipping? that's kinda high. lemme know if the local deal falls through. i think he'd be willing to pay $250 including shipping. idk u find out how much shipping would be n let me know.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Greddy Type RS bov
Tial 38mm WG
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Soon to have:
Old 07-06-2009, 10:23 PM   #12
He's willing to pay me the $250 and come pick it up, no shipping needed, I'll let you know what happens.
Its going to cost $105 to ship to you, so keep that in mind.
Old 07-07-2009, 12:01 PM   #13
jlicrx's Avatar
DX and Si axles are identical - any of the axles will fit at the transmission end - all of the L3 transmissions, except for the ZC, have the same differential side gears where the axles go in - the ZC transmission uses an intermediate shaft and larger axles like the Integra - the large bearing transmission cases, like the Si, use a different seal than the small bearing cases, but the axles are all the same at the transmission end - the seals have the same inner diameter and different outer diameters
ZCspeed Racing
Civic CRX Si 88-91 2nd gen 5 speed transmission used RSS-Bot Auctions 0 06-12-2009 01:03 AM
wtb: h22 5 speed transmission FearDisH22a4 Parts: For Sale/Trade/Wanted 2 12-13-2008 08:46 PM
WTB: 88-91 civic 4 speed transmission sIR-TecH Parts: For Sale/Trade/Wanted 5 04-17-2008 07:37 AM
4 speed to 5 speed transmission 06busa Civic and CRX - EF 2 12-26-2007 10:26 PM
WTB: H22 5-speed transmission jam05pr Parts: For Sale/Trade/Wanted 2 10-26-2004 11:21 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
